Results 1 to 11 of 11
Thread: hello.. question on value!! 250r
    Oct 2011
    cleveland
    3
    Hi, sorry to post this question in here but it won't allow me to post anywhere else.
    I have an (I believe 85) 250r. I remember its the last year before water cooled. I have to check but its at my fathers house. Anyways... its been sitting for the last couple years now and he wants to get rid of it. I spent a bit of time on it when I was younger. Everything was in excellent condition when we bought it. The plastic was great, not faded, everything was painted and fresh. It was very nice.
    However 2 things.. 1 the pipe got dented in. It was repaired but looks kind of ugly. Will probably need a new pipe. and 2... the connecting rod bearing went. The cases were split but we never could come up with the money to order the parts. So everything has been sitting.
    Wondering what something like that might be worth in the real world today. I know if it was mint like it was when we got it it'd be worth a bit, but with the motor being apart and needing some parts and the exhaust.. what is your opinion? Would like to help him get rid of it and need to know where to start so that I'm not wasting my time or anyone elses. I will try to get over there to take pics soon.
    Thank you for the help.
    Billy Golightly's Avatar
    Live Oak, FL
    15,070
    Sounds like it needs some work and parts for sure with a rod bearing that went out. Depending on the condition of the rest of the bike your looking at in my estimate between $500-$1000. The upper end price being if its in really cherry original condition other than the motor and pipe work.
    Thats my .02 and welcome to the site
    OK
    5,450
    The first year of watercooling was 1985. You must have an 84 250r. In the condition you describe, it honestly isn't worth all that much.. It depends on the condition of the plastics, the tank, the tires if they are oem tires. The 85-86 watercooled 250r's bring the money. The 81-84 air cooled 250r's not so much. Unless they are pristine, or have period correct performance parts on them.
    Honestly depending on the condition of the plastics, seat, etc. It's worth $300-$400. Pictures help a lot
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    Oct 2011
    cleveland
    3
    Thanks guys. Was honestly thinking like $350 and i'd be happy.. so that kind of confirms. Will probably get it up on the classifieds when I get some pics.
    Nov 2009
    Medina, Ohio, United States
    18
    Are you from Cleveland Ohio? If so I might be interested once I see pics.
    85 250r w/short track kit
    85 70 w/ 140
    84 Auto X
    84 110
    85 200x W/ hondaline axle
    Matrix's Avatar
    Matrix is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2011
    Newton Falls, Ohio
    379
    Im in portage ohio and paid 675 for my 84 250r, however it did not need work other than rear brake cylinder and chain. I think if you fix it up to good running condition your looking at 450-600? And yeah get some pics up.
    Oct 2011
    cleveland
    3
    yep, cleveland ohio. will get pics asap!!
    May 2011
    eden,ny
    3,481
    Quote Originally Posted by Matrix View Post
    I guess matrix doesnt know what a rod bearing is or what it takes to make the repairs
    Matrix's Avatar
    Oct 2011
    Newton Falls, Ohio
    379
    Quote Originally Posted by ben6626 View Post
    Sorry I had accidentally skipped that part but non the less I do not know what a rod bearing is or what it takes to make the repairs...
    Enlighten me will you?
    Last edited by Matrix; 10-27-2011 at 12:40 AM. Reason: Correction of ignorance is necessary.
    Blossvale NY
    4,563
    If the lower rod bearing fails, you are looking at $100+ to replace the rod, and will probably need the crank rebuilt/replaced. Crank rebuild your looking at at least $100 labor, plus parts (crankpin, bearing). And this is assuming no crankcase damage was done. Plus, you would certainly want to measure up the piston and bore and address any wear issues there while its apart and your are spending the $$$ on repairing the bottom end.
    So basically, best case scenario, if it ONLY needs a new rod, lower rod bearing and crankpin, he's looking at $250 and up around here.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Mar 2007
    FL
    583
    like dcreel said the year before water cooled is 84 and not worth mutch non running. You my want to part it out if all else fails. You will probably make more money this way.
