Hey guys, i am starting to work on my senior project, it is a requirement to graduate high school. since i am taking auto body in school right now i have decided to make a custom chopper gas tank. they want us to choose a field that we would like to pursue on our future career so i decided fabrication. so after talking with my teacher for a while, i thought the best thing i could do would make a custom gas tank. it will not be functional, but i do want it to look like it can go on to a chopper. i will put on a gas cap and petcock. so i was wondering if there were any fabricators or custom guys out there that could help me out a little whit some advice. here is a picture i found of what i was thinking of going with. at school we got a sheer, and sheet medal bender so i found this most suitable. but we don't have an English wheel so it would be tough to have one with round sides. suggestions and advice would be much appreciated.
thanks
Jimmy
this is the info with the picture:
Chopper Prism 3.8 Gallon Gas Tank . Gas tank accepts a left side petcock and has a fuel capacity of 3.8 gallons. Point Prism tank includes strap type mount system. The back of the tank comes down into a point. This tank is 25" x 5" deep tunnel length and is 12" at the widest point. Check the tank for flaws and fit before painting. Do not grind or sand the seams or joints. Clean the inside of the tank. It is suggested to pressure tesr and use a tank sealer. We suggest using Kreem gas tank combo kit, clear, condition and seal to help stop leaks and prevent corrosion. Check petcock opening, making sure the petcock can be easily installed. Petcock should be masked or plugged during painting for easy installation of petcock. Fits: Custom application Style: Prism Measurements Top Length: 27" Bottom Length: 21.5" Rear Width: 0.5" Front Width: 10" Rear Height: 0.25" Front Height: 8" Front Tunnel Height: 4.5" Rear Tunnel Height: 1.5" Tunnel Length: 25" Tunnel Width: 2-3/8"![]()
