Thread: 83 ytm 225dx headlight
    Oct 2011
    Minnesota
    3
    I cannot figure out how to get my headlight to work. The neutral light works as does the taillight about the headlight. I found a couple fuses and they are good. Does the battery need to be fully charged in order for the headlight to work. I just bought it and the battery is completely dead it does not even take a charge. Or when else could it be thanks for any help I am at a loss.
    Matrix's Avatar
    Matrix is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2011
    Newton Falls, Ohio
    379
    Is your bulb good? I have no knowledge of the DX's but the headlight and the tail light should run off the stator. If it is supplying good power to the system which it sounds like it is (the trike is running correctly) then I would check the bulb first.
    Oct 2011
    Minnesota
    3
    Hi..thanks for the reply. I forgot to mention I did replace the bulb so it is not that. Switch then?
    Dec 2010
    Pennsylvania
    510
    it is probably the switch, i do not have a battery in mine, and it works. it gets brighter as the rpm's go up, but no battery is needed.
    Oct 2011
    Minnesota
    3
    Any idea where to find 1 of those?
