I dont know but a few of you might remember a few of my past threads about major issues with my 250r. and turned out i had chunks of metal in my crank bearings that were the culprit of most of the issues...well i bought a fresh rebuilt engine from a member on here. and finally got some time to install it last night and got it running today
4th kick the new engine came roaring to life. sounds very good in my opinion...i am running it at 28:1 to kinda help break it itn, then will go down to 32:1 after i burn through the tank full that i have now..like i said it runs great, but when i give it gas, it does bog and chug(obviously rich, from looking at plug, and will spit oil on your hand if you put you hand behind the silencer) but it will clear itself out, but it will smoke black. im not sure what the black means, but when i let it come back down to a idle it straightens out, with a very light bluish color, my guess from being rich. im not sure which way to go in jetting, but i do believe i have the factory main jet in it. 148 if my mind serves me correctly? but im just making this thread in hopes of maybe getting a few opinions on the black smoke, and bogging it does...i will post a video of it later and you can see it blowing the black smoke for very brief moments.....but for the most part, im happy to have a running 3 wheeler again. now i need to finish the rebuild on my banshee and everything ill own runs lmao
also, i dont know what is up with my clutch situation. i pulled the clutch cable, and bracket off the old motor (never messed with its adjustments) put them on the new motor and its nowhere near able to pull the clutch out. i got it adjusted to where it will disengage the clutch maybe halfway, but im out of adjustment room on my cables, their maxxed way out, as in i only have 1 thread on both ends for adjusting left...i did order a new clutch cable, but my question is, how can there be that much difference between my clutches from motor to motor? i pulled both clutch pressure plates off and found the clutch lifter, and the small ball bearing in both motors, and both lifter rods are straight, and not bent...so i dont know what is up there, any input on this would be helpful too...
