Results 1 to 8 of 8
Thread: two qestions re Honda 185s
    foster is offline Just Too Addicted Arm chair racerJust too addicted
    Sep 2003
    East Coast Canaduh
    522
    New rider here, so it's stupid question time, and I got two of 'em.
    1) Under the rear axle, slightly to the right, there is a bolt sticking out of the bottom. What's it for? To drain water out of the brakes? I opened it up and water poured out, so . . .
    2) Isn't there an air filter in these things? I think I see one under the seat, but it's like a major job to get the seat off -- it's bolted down there tighter than a tank turret. Is that where it is?
    Thanks from a true newbie.
    FOSTER
    May 2002
    Dublin, Georgia
    635
    Filter
    On the 185s your seat is probably mounted to the fenders. The seat and fenders remove at the same time by a release lever at the back. After this is off the airbox with filter is easy to get to.
    84 ATC200X--Wife rode it once, now I can't get it back.
    84 ATC250R--Trying to find piston for 300R kit.
    85 ATC350X--Project finally under way, slow progress. For pics: http://groups.msn.com/ATCfriends/350xproject.msnw
    84 ATC200S--Freebie from a neighbor, needs topend rebuild and tires.
    Sep 2003
    East Coast Canaduh
    522
    Thanks ejc.
    I didn't see a release lever, and neither did my two drunken, uh, "assistants."
    But maybe we didn't look hard enough. Then again, maybe it's been busted off -- unlikely though since the bike had only one previous owner, and he was a little old man.
    I'll search again tonight.
    Any idea on that thing that looks like a drainage plug under the rear axle?
    Cheers all.
    May 2002
    Dublin, Georgia
    635
    Check these out
    Seat latch under rear of fenders(fenders not in picture). #12 located right under rear of fenders.
    Sep 2003
    East Coast Canaduh
    522
    Excellent graphics.
    I don't see my mystery bolt/plug in there, though, though maybe it's #25, (I think the number is 25, it's right under the washer #29 anyway.)
    Again, I guess I'll take another look when I get home tonight.
    Thanks for your input. Very much obliged.
    May 2002
    Dublin, Georgia
    635
    Cool
    I have a 200s I am partin out and will look to see if I can figure out what the bolt is.
    The schematics cam from partsfish.com
    Aug 2003
    37
    Yeah I'm pretty sure that's what it is. My '81 doesn't have a bolt it just has a cutout in the bottom of the brake drum cover in case water gets in there. Clymers manual just calls it a drain cutout.
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    First of all what year is the 185S? Mine is a '82 and there is a latch under the rear fender towards the ass end. Your airbox is there and if it is a '82 these airboxes are a pain in the rear, you have to take the whole box out, and undo the little bole in the back of it and pull the filter out. That plug you were talkin about is the brake drain plug.
    TF 07,08,09,10,11,12,13,14!
