TriZ / Warrior 250R Shock Dimensions
Its nearly impossible to measure these IN the trike, and theyre not real quick to remove. The deal is I have a shock that looks like it would fit on the Z, and I dont want to do all the work to find out, so if somebody has a Warrior or TriZ shock handy, could you possibly measure the length - hole center to hole center, and the width on the bushings the bolts go through. I was told ot came off a TRX250R, and if somnebody happen to have an 85/86 ATC or a TRX250R they could measure that would make things easier too. The shock I have has preload adjustment, and no resevoir. It came off a 250X with an aftermarket extended swingarm, and Im not sure of its origin or what it fits.
//ArrowChat Integreation Code
