Hi,
been checking out the site for a while now and have finally decided to register and make it official.
I am having some serious idle problems with my trike even though the carb has been cleaned thoroughly and checked for leaks. the idle gets worse as the engine warms up which leaves me to believe I have a fuel mixture problem.
I would like to rebuild the carb completlely but I cant seem to find a kit to provide all the parts. only to buy the parts individually from yamaha which probably isnt available anymore and even if it was would be ridiculously expensive.
I was under the the impression that the timberwolf250 carb kits and the yfm200 carb kits were similiar to mine.
my question is if I were to buy both of the carb rebuild kits would between the both of them give me the exact parts I need to rebuild my ytm200e carb
if that wont work could someone pass along some part numbers so that I know exactly what needs to be ordered that is missing from those kits and which kit if not both of them should be ordered.
Thanks in advance
