Results 1 to 15 of 15
Thread: Stock Exhaust Baffle 350X
    KgoX is offline New to the board Arm chair racerNew to the board
    Oct 2011
    CA, usa
    54
    Can someone with a stock muffler on a 350X do me a favor and measure the opening size (the actual size of the hole where the exhaust comes out-just to be clear), my 350X didn't come with a baffle but the baffle out of my XR650L fits right in but I need to know If it's choking it down with a smaller opening then the 350X, I still want to get the stock baffle in there If I can track one down as I still need the XR650L baffle for my motorcycle.
    thanks.
    Oct 2011
    CA, usa
    54
    So I did some more using of the search option and found that this question has been asked by a couple other people with no response, is it because no one has a stock pipe or is it a government conspiracy?!?
    Oct 2011
    CA, usa
    54
    government conspiracy!!!!! I KNEW IT!!!!!
    Dec 2010
    washington state
    681
    stock?
    GOT MUD?:
    Plattsburgh, NY
    2,311
    sorry no stock exhaust here....
    TPC TRIKES
    FSU Powersports
    RNS Powdercoating
    Oct 2011
    CA, usa
    54
    Thank you, to the both of you who responded, I would rather people respond with "stock pipes? we don't neeeeeed no stinkin' stock pipes!!" rather then having virtual tumble weeds rolling across the forum planes.
    I know someone out there must have a stock pipe...I'm going to keep trying.
    gus's Avatar
    gus is offline Just Too Addicted Arm chair racerJust too addicted
    Jul 2011
    tucson arizona
    453
    haha lucky you i have owned 2 350x 1 85 and i believe the other was an 86 i have 2 "stock exhaust" (headers) that mount on the engine i have some engine parts (botton half of the engine and othe parts) and the oil-cooler they have been sitting for awhile in a plastic tub rotting i have no use for them so might as well get rid of'em . if your intreststead you can send me an email on parts you need gusfernandez350@yahoo.com
    Dec 2010
    washington state
    681
    nuthin really wrong with stock just seem to always have some aftermarket pipes on the ones ive gotten , hopefully gus will have what you need
    GOT MUD?:
    Oct 2011
    CA, usa
    54
    from what I have researched the 250R is 32mm compared to 20mm on the XR650L so the 350X is............??
    Nov 2010
    Crawfordsville, Indiana
    144
    Since my X died the other day and its now in pieces, and brings a tear to my eye just looking at it in this shape, I think I can overcome the feelings for a few and will check when I get home in the morning for you, if I remember.
    A possum is a flat animal that lives in the middle of the road!
    2-85 125m
    85 350x Astro
    86 350x
    80 185
    My Feedback
    http://www.3wheelerworld.com/showthr...Chickengizzard
    Jun 2009
    Leander TX
    2,217
    If I understand the question, you want to know the size of the hole in the insert that goes into the end of the stock baffle?
    Approx 42mm on my 85 350x. Approx because I could not quite get my caliper into the hole.
    Oct 2011
    CA, usa
    54
    Is this the hole you measured:
    If so, then that makes the idea of a 650 only having a 20mm opening in comparison kind of ridiculous.
    ok,Chickengizzard,your up, can you second the opening size?
    the inserted picture of the baffle is from a '85 ATC 250R.
    Nov 2010
    144
    Mine is 38.3mm side to side and 37.9 top to bottom. I figure there's some warpage. So 38mm
    2-85 125m
    85 350x Astro
    86 350x
    80 185
    My Feedback
    Oct 2011
    CA, usa
    54
    great! thanks again both of you.
    well, now I know that the 650L baffle is really choking it down and it's interesting to know that the 350X baffle is 6mm bigger then the 250R,
    this also means that I need to either get a 350X baffle,manufacture a new baffle or get some aftermarket muffler...
    Oct 2011
    CA, usa
    54
    350X baffle opening size 38mm, ATC 250R baffle size 32mm,XR650L baffle 20mm,
    to summarize...ATC 350X baffle opening size 38mm, ATC 250R baffle opening size 32mm, XR650L baffle opening size 20mm,
    Hmmmm...looks a bit redundant next to the title...
