Thread: 1981 ATC 250R - Driven Sprocket Flange
    Oct 2011
    Abbotsford BC Canada
    93
    Hi I just picked up a 1981 ATC 250R, well actually I was told it was a 1982, but it has a drum brake on the rear, and the serial number is within the range of the 1981 model year. The rear axle is bent, and I'm going to get it straightened out, so I picked up a manual and started the project. All is going fine, and the axle is removed, as well the sprocket has been removed. However the manual doesn't describe how to remove the DRIVEN SPROCKET FLANGE from the axle. Any ideas? Looking forward to getting this axle straight Thanks in advance!
    Tucson
    1,652
    That is pressed on the axle, no reason too remove that too have it straightened!
    Oct 2011
    93
    Perfect thanks, I found a local shop I'm going to take it in tomorrow.
    Oct 2011
    93
    Update the axle is straight now
