Results 1 to 15 of 18
Thread: Help! clutch differences between 85/86 250r?
    Jan 2011
    Greene,Ia
    688
    ok, i figured id make a thread strictly on the clutch on my 250r. i have a 85 r, with a 86 trx 250r motor in it....im having issues with my clutch. my cable just simply wont pull the clutch out enough to disengage it. i tried a brand new cable, but still same issue. there is about a 1/4 turns worth of free play in the clutch actuator rod. i took both clutches apart on both my 85 motor and this new 86 motor, and found the actual clutch rod (the rod that pushes into the pressure plate) was about 1/4 inch shorter in the 86 motor...so i swapped my longer rod into the 86 motor and still have the same issues....i was talkign to a guy at work about this and he said check the bracket that holds the cable itself to the motor....
    at last, i found a possible culprit. i did find that both the 85 and 86 trx 250r and 86 atc 250r's had different clutch cable holders on the motor. both the 86 atc/trx have the same bracket....but are these 2 brackets really that different???
    what im hoping for is for someone to maybe help me with a picture of this bracket, or maybe some different ideas on what my clutch issue could be.....any help, input or ideas would be very helpful at this point
    2006 Yamaha Raptor 700
    2004 Kawasaki KFX700 V Force
    1985 Suzuki LT230GE(wifes toy)
    1985 Honda ATC 70
    1979 Honda ATC 70 (daughters toy)
    Aug 2010
    Southern Oregon Coast
    932
    is the ball bearing still in there, on the end of the rod. #28
    Jan 2011
    Greene,Ia
    688
    yes it is in both rod ends on each motor.....and their both free and not stuck
    1985 Honda ATC 70
    Your rod is too short, check the spec. Should only be 1 ball......
    Best thing for these is the 89 update kit.
    Jan 2011
    Greene,Ia
    688
    sorry to confuse you. there is one ball on one end of the rod, on both motors. 1 ball and rod per motor... but how would the rod be too short tho? where do i find the spec size for this rod?
    1985 Honda ATC 70
    The rod and pivot arm wear out, I imagine the shop service manual has the spec.
    Again, just buy the 89 update kit for 85$ and you'll be much happier......
    Jan 2011
    Greene,Ia
    688
    can you tell me if part number 10 in this pic is adjustable???? or whjat is the difference between the 85/86 to this 89??
    1985 Honda ATC 70
    Jan 2011
    Greene,Ia
    688
    if i buy the 89 kit does it come with a new pivot arm??
    1985 Honda ATC 70
    No, not adjustable. No, no pivot arm. If your arm is worn, thats part of your issue........
    You get a new rod that works with a thrust bearing (and washers) for smoother action.
    Do a search, I even tossed them in the 85R I had when I had cable issues and action that wasn't smooth.
    Jan 2011
    Greene,Ia
    688
    well i just found the 89 kit on ebay for 65 bucks shipped, so i bought it. cant go wrong. ill inspect the pivot arms when i get home from work, and might buy as new one of those as well
    1985 Honda ATC 70
    Jan 2011
    Greene,Ia
    688
    did some tinkering today. took both pivot arms out of both of my motors...the pivot arm in the 86 motor had a good sized dent/divet where the pusher rod rests on it. where as my 85 pivot arm looked fine. so i put my 85 arm into the 86 motor, and now i have very minimal free play in the arm before it tries to disengage the pressure plate. it does disengage it a good amount but it still does drag a tiny bit. so all i can really hope for now is the new 89 kit will solve the rest of this issue, or ill be forced to make a longer push rod
    1985 Honda ATC 70
    Oregon
    2,471
    $65 for the update kit, Can you post a link ?
    If you have Bought a item from me, Please leave me feedback
    If your buying a item from me check my feedback
    Click on link ~ http://www.3wheelerworld.com/showthr...ceaserthethird
    Nov 2004
    Waterloo IL
    2,701
    I had the same problem on my 85 250R when switching to a newer engine. I drilled a second hole in the cable mounting bracket that bolts to the engine and moved the bracket farther forward. Problem solved.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    Jan 2011
    Greene,Ia
    688
    Quote Originally Posted by ceaserthethird View Post
    i just got lucky. i started using the part numbers for the update kit from different parts sites, and started searching those numbers on ebay, and found just a normal guy (as in not a ebay business/store) that had one for sale so i snatched it up. still brand new in packaging
    1985 Honda ATC 70
    Jan 2011
    Greene,Ia
    688
    Quote Originally Posted by Blown 331 View Post
    i was considering modifying that bracket also
    1985 Honda ATC 70
