Results 1 to 11 of 11
Thread: 300ex with Honda CB650SC Nighthawk engine - Almost done! - need some help
    stevensj13's Avatar
    stevensj13 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2011
    Willow Springs, North Carolina, United States
    338
    Alright guys, here I have my Honda 300ex with a CB650SC Nighthawk engine and frame. the front end of a 300ex has been remanufactured and bracketed and welded onto a CB650 frame, and the swingarm from a 300ex was a direct bolt up. Now, I have the wiring done, and other than a new chain/sprockets then its pretty much ready (haven't started it yet but thats on today's to do list). The chain for a CB650 nighthawk is like 630 or something, and the one for a 300ex is about a 520 I believe. Now, the 300ex sprocket and the CB650 nighthawk sprocket are bolth 4 bolt pattern. My question is, would the CB650 sprocket bolt onto the 300ex swingarm? I would try for myself but I don't have the wheels from the nighthawk and therefor no sprocket. I really would like to get this thing done today, test and fine tune during the week, and tear up the drag strip next weekend!
    My baby - 1984 Honda 200X, Clark Desert Tank, Supertrapp exhaust.
    stevensj13's Avatar
    Jun 2011
    338
    here are some pics for the interested people mmmmm.jpgooohhh.jpgrear.jpgsexy.jpg
    partsmaster's Avatar
    partsmaster is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oklahoma
    153
    Hey I'm interested! Looking good, glad 2 see someone else utilizing a streetbike powerplant. Can't help u much with the rear sprocket issue.... I'm goin a different route by shoehorning a cbr600 engine into a 250x frame, luckily 520 front sprockets are available for the cbr engine so I used that and kept the stock rear sprocket..... good luck!!!
    85 ATC250ES
    85 ATC350X
    85 ATC250R
    82 ATC70
    84 ATC200X
    79 ATC110
    ATC500
    81 ATC250R
    87 TRX250
    08 TRX700XX
    96 TRX400FW
    00 Rancher FM
    05 TRX400EX
    87 TRX330R
    TRX600
    01 Rubicon
    00 TRX450S
    88 Foreman
    87 TRX350D
    98 TRX300tw
    05 TRX450R
    Jun 2009
    Leander TX
    2,217
    That's kinda wild!
    Might be easier to find a 520 sproket that finds the 650 engine and use the TRX sprocket on the swingarm. These guys have pictures and measurements for sprockets.
    http://www.jtsprockets.com/
    Do the sprockets line up?
    stevensj13's Avatar
    Jun 2011
    338
    Quote Originally Posted by jb2wheels View Post
    That's kinda wild!
    The sprockets line up, but there is a hump in the swingarm where it mounts that the chain rides on, so I was hoping for a tall CB650SC rear sprocket to mount, so it can clear the slider/swingarm.
    stevensj13's Avatar
    Jun 2011
    338
    Cleaned the carb and shes not running. It was a to get out of the frame, thats for sure! I'm going to play with it today. Does anyone know how to tune these four carbs?
    stevensj13's Avatar
    Jun 2011
    338
    had a very busy weekend of working on some machines and didn't update anything, but I do have an update now. I cleaned the carburators and bypassed the fuel pump with a gravity feed (stock tank, stock placement. all works, not sure why there was a fuel pump anyway ). Got her running, idles great and revs right up. Great engine with no smoke either. I have decided to get custom front and rear sprockets made. I am thinking of getting the front at 16 tooth and the rear at 51 tooth, giving me more bottom end and still keeping a fast enough top speed. I might get a second lower rear sprocket made for top speed when I am murdering alky banshees on the drag strip. All and all its coming together better than expected. Need sprockets and its ready to ride! I'll have a video of the first test ride.
    Blossvale NY
    4,563
    Look forward to seeing those vids!
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    stevensj13's Avatar
    Jun 2011
    338
    I'll get a startup and description video today, won't be a ride video since I don't have the sprockets yet. Still, hearing it run is a blast hehehe
    Tucson
    1,652
    What happened here? Did you give up?
    stevensj13's Avatar
    Jun 2011
    338
    Traded it for a very nice Jeep Cherokee
