Results 1 to 8 of 8
Thread: 350X ring end gap problem
    Nov 2004
    Waterloo IL
    2,701
    I'm putting new rings in my 350X and I'm having a problem with the ring end gap. It's a stock bore and I measured the piston at 81mm. I bought new Honda standard bore rings for it but the ring end gap is .075! The old rings are roughly the same, around .075. The spec is .008 to .014. I had not seen this engine that I'm rebuilding run but I told it smoked. Any suggestions here? I was hoping to have this thing together today. I can't put it together like this.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    glendive, montana
    1,822
    are you sure the smoking issue was from the rings? Could it possibly have been from bad valve guide seals? I would have ran it before tearing it down, simply because hearsay is a nasty thing to trust.
    Nov 2004
    Waterloo IL
    2,701
    Quote Originally Posted by muthey View Post
    I can't imagine anyone selling an engine would lie and say it smokes when it really does not. I sure wasn't going to put it in my bike just be sure, and have to pull it right back out.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    82,79 XL500R
    83 ALT50
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72 SL100
    70,69 Z50
    glendive, montana
    1,822
    I understand that, but smoking is not always burning oil it could be running too rich or moisture build up as well did he tell you what color the smoke was?
    Jan 2011
    Brazil, Indiana
    2,087
    Time for a bore and piston.
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    murfman is offline Just Too Addicted Arm chair racerJust too addicted
    midwest
    467
    What he said^^^ You need to bore it and get an over sized piston and rings. OR you can go for a big bore kit. I am putting together a 96mm bore 350 right now. If you want to go stock I have a clean piston and jug from my motor It did not smoke and had good compression before I tore it down for the build. PM me if you are interested.
    WilliamJ's Avatar
    WilliamJ is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2010
    Poole, England
    157
    Sounds like the bore is either very, very badly worn or it has been bored out by half a millimetre already.
    If it is tapered (narrower at the bottom) then it suggests wear. If it is straight then it has definitely been bored over stock. Get a machine shop to measure it.
    Bill
    Custodian of:-
    85 Tri Z - need rear plastics to go with Mosh seat cover
    83 200x - engine being rebuilt but lodging with a friend
    85 250r - also lodging with a friend until I have a new shed
    ....and a different kind of Z
    Nov 2004
    Waterloo IL
    2,701
    Yeah a piston and bore or a big bore would definitely take care of it. I must have made an error in my measurements. A friend of mine is tearing down his smoking 350x and is going to buy my new rings if his is standard bore so I hope it is. Now I need to figure out if I'm going used, big bore or 1mm over 10.25 Wiseco. I'm leaning towards the Wiseco but I'm waiting on more info on the big bore.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    82,79 XL500R
    83 ALT50
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72 SL100
    70,69 Z50
