Results 1 to 12 of 12
Thread: Removing smeared auminum from a cylinder?
    Masshole
    2,191
    Picked up a saw with a melted piston. I think the cylinder actually didnt gouge, but has some pasted on aluminum. Whats the best plan of attack? Its a coated alum cyl. Any sort of acid i can use to loosen it up? I dont want to take a hone to it.
    Eastern Long Island
    1,688
    I've been told Easy Off oven cleaner works, never tried it myself though.
    Lots O Trikes!!!!!
    Blossvale NY
    4,563
    Carefully used, muriatic acid will do the trick. But, take ALL precautions, and don't over-do it, especially with a plated cylinder....
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    I've used Muratic in a pinch to put back together a motor. I made a "swab' with a welding rod and a bunched up piece of shop towel. Worked good enough to run it for a few races!
    yes Muratic,,,, does the trick..
    NEPA
    7,051
    Muratic and a very quick hone : )
    Nov 2007
    ulysses pa
    1,231
    Quote Originally Posted by 200xman View Post
    i've used oven cleaner several times with success..
    Masshole
    2,191
    Very good, i was leaning toward the acid but was scared. Thanks for the green light to use it!
    Be very careful with it Jeff. It's nasty stuff!
    Sep 2007
    100mi west of Chicago
    3,582
    My dad and I used Muriatic on a Yamaha Phazer snowmobile that melted a piston. As far as I know that sled is still running somewhere.
    Rob
    Masshole
    2,191
    Worked mint, was like wiping my ass, a little scrubbing and its all gone. In fact, i may keep a bottle of this in the dump-house for the day after taco night!
    Jan 2011
    Brazil, Indiana
    2,087
    Just dont apply too much pressure and go front to back. LOL
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
