Results 1 to 3 of 3
Thread: 86r chain lube?
    jdowd123's Avatar
    jdowd123 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Sep 2011
    Homestead fl
    212
    86r chain lube?
    Just pulled the chain off my r and cleaned it. What are you guys using for oil or lube. I have some Amsoil Heavy duty metal protector its says safe for all chains. Can I dunk in 10-30 motor oil.
    O.C., Oregon
    921
    I use PJ1 chain lube, it works well and is nice and tacky so it stays on the chain. 10w 30 will work but its gonna be messy as hell and wont stay on there as well as nice and tacky chain lube. I've also used napa chain lube in a pinch and never had any problems with that either..
    1978 ATC70 w/ Piranha 140cc
    2017 YZ 250x- Braap
    audioworks04's Avatar
    Oct 2008
    Kansas City, KS
    332
    I use chain wax when I lube them on the bike. In the off season I soak all my chains in kerosene and then used motor oil. Just make sure you dry off really good before you install and ride otherwise its and oily mess.
    86 atc250r stock sand only
    88 NX250 mint rainy day
