If you are into the mud that deep take your trailer hitch off..
I found my machine kept getting hung on the hump on the deeply rutted spots.
I promise it will make as much difference as those big azz tires..
And don't forget to change that differential oil..like after every seriously muddy ride!!
Current toys..
1986 Honda 350X..trail bomb!
Current non-trike toys:
1990 Honda TRX300FW
1995 Seadoo GTX
1998 Polaris Touring 500
1998 Club Car (electric)
Looks to me like the fenders will rub when the suspension be comes compressed. Did you make sure?
1985 Honda 250r x2
1986 Honda 250r
1986 Honda 250sx
1985 Honda 250sx x2
1985 Honda 350x x2
1986 Honda 350x
1984 Honda 125m x4
1984 Honda atc 70
Yamaha tri zinger
Yamaha 4 zinger
Brap braaaap
you will be damn near unstoppable in mud with it.
my concern would be running into sticky mud which will weigh your fenders down, rubbing your tires or even worse destroying your fenders when you throw it in reverse and your tire catches the edge of your plastics
85 1/2 Tri-Z
85 350X
85 250ES
You shouldn't have any problems, looks fantastic! You need to put another one on the front.
27-12-11s all the way around, only rubs the fork boot a little bit...Plenty of riding and no problems.
Want to race?
1974 Honda ATC 70
1985 Honda ATC 250 ES Big Red
1986 Honda ATC 250 ES Big Red
2008 Honda Rancher 420
1983 Hustler 945-HK 6x6 - Fire Breathing 627cc V-Twin Monster
2010 Chevy Silverado 1500 4x4 LT
1983 GMC K10 Sierra Classic Suburban 6.2 Liter Diesel
My Feedback:http://www.3wheelerworld.com/showthr...-for-Stonewall
There is no Z in Diesel!!!
Doug: I liked keeping the hitch on for fun times like this. But if I'm going mudding I should go all the way.
Jason: My shock has always been on stiffest setting, and at full compression it doesn't rub. Tighest spot is where pictured.
And I have the same concern bigredridr, gathering material for rear lift.
Thanks to your pictures Stonewall I went with 27's, I was initially just gonna do 25x12x12 Swamplites or SuperLights. Looks like it works for you so I did as well. As for front tire, I'm not yet convinced an aggressive tread is needed up there, I do want it big, for clearance, but maybe not deep lug.
