Results 1 to 11 of 11
Thread: 350 carrier zerk
    texas
    567
    350 carrier zerk
    I ordered a new dual row carrier that has a zerk. I really dont understand how that is supposed to work because its still inside the swingarm. Or is it to prevent the need to pull bearings and do a full service on the carrir.
    blkstangman88's Avatar
    blkstangman88 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2010
    marysville
    282
    i was curious bout the same thing. maybe ull need to cut away a slot to reach the zerk
    Aug 2010
    Southern Oregon Coast
    932
    I thought the same thing when I helped my brother put in his dual row carrier. I think I've seen people cut a small hole in the carrier housing to access the zerk.
    audioworks04's Avatar
    Oct 2008
    Kansas City, KS
    332
    No, the idea is not that you need to modify your swing arm. Please do not drill/cut holes in your swingers, they are not designed for this and no reason to destroy an oem. Alot of aftermarket swingarms have openings there so that the zerk can be accessed, also the RAD bearing carrier has the zerk on the side for easy access. All you need to do is once or twice a year pull your caliper and lock nut and slide the carrier out far enough to access the zerk and grease it. The amount of grease that you can fit in there will be plenty to last most of us more than a year. If you ride in the water alot you might need alittle more attention with your bearings.
    86 atc250r stock sand only
    88 NX250 mint rainy day
    Lancaster, PA
    1,738
    your right, it is to easy the service of the bearing but you have to pull the carrier or you can dril a hole in the swingarm(not a slot) and just rotate the carrier to the hole for grease. I recommend finding something to plug the hole like a plastic cap.
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    1973 ATC 70 (resto project)
    and many more!!!
    Blue Line Graphics
    Apr 2002
    s.w. michigan
    6,498
    It is alot easier to grease when you have a exposed Zerk. Honda should have installed them in the first place IMO.
    See post 8 http://www.3wheelerworld.com/showthr...0x+grease+zirk
    * too bad the older pictures are not viewable*
    GeoD's Avatar
    GeoD is offline At The Back Of The Pack Arm chair racerFirst time rider
    Carbon County, PA
    170
    I was going to drill a hole in my swingarm after replacing my stock carrier with a double row. After drilling I was going to tap the hole so I could put a shallow bolt in with a rubber washer to seal it up after greasing. But, I couldn't bring myself to drill the swinger. I decided that if I need to oil it I will pull the carrier out. Hell, my stock carrier lasted 21yrs without greasing. That is until my rear came apart when I was riding it and coal dust, stones, dirt, etc... got in the whole assembly and killed it.
    Geo D
    1+2=ME
    My Toyz
    PA
    3,515
    Those zerks are just there for show, you do know you have sealed bearings right?
    If you remove the inner bearing seals then your zerk will do some good.
    WWW.HREATV.COM
    murfman is offline Just Too Addicted Arm chair racerJust too addicted
    midwest
    467
    Quote Originally Posted by SWIGIN View Post
    ^^ This ^^
    I did pump it full of grease before I slid it home in the swingarm just to keep the spacer from rusing into a solid blob around the axle shaft. I then slathered the entire carrier with grease before I installed it into the swingarm as well.
    NEPA
    7,051
    All the newer "good" ones have the zerk on the outside,in between the chain adjuster knobs. They make a WHOLE lot more sense! And generally,,,the boys making these DO remove the inner seals ,,hence the zerk. That's why the aftermarkets don't last near as long unless you go to the ridiculous lengths to grease them...
    PA
    3,515
    No they dont remove any seals.........
    WWW.HREATV.COM
