Results 1 to 15 of 22
Thread: Ice tire help
    Nov 2010
    Crawfordsville, Indiana
    144
    Ice tire help
    I'm studding a set of nobbies this year for ice racing my 125.
    Anyone have any recommendations on how to stud them?
    Should I just put 1 in each lug or skip rows or diagonal, which would be best?
    A possum is a flat animal that lives in the middle of the road!
    2-85 125m
    85 350x Astro
    86 350x
    80 185
    My Feedback
    http://www.3wheelerworld.com/showthr...Chickengizzard
    Jul 2011
    Lilly PA
    1,480
    I have never actually used a studded tire but the last one I saw had every other knobby row cut off then studs in the remaining. Count you rows because you may have to go a different route if its odd numbered because you would have two in a row messing up the pattern! Not sure if this is the correct way or even how it works, just relaying what I saw!
    Just sit back and chillaxx
    Nov 2010
    144
    Their are fourty rows. The front tire of the 125 in the picture above is the same style tires I'm using. I was thinking about doubling up the studs in the two or thee middle rows on the front tire and doing like you said in the rears as far as skipping rows. I've seen pictures were someone did a diagonal pattern on the rear, figure it would help better having them set up in this pattern when slidding in corners.
    2-85 125m
    85 350x Astro
    86 350x
    80 185
    My Feedback
    What you just said makes sense, you have the idea.
    Once you have them installed and you test it out, you can "index" the screws to provide more or less traction depending on what you need the tires to do. "Indexing" is turning all the screw heads in a specific tire to provide more or less traction.
    A low profile tire with not much sidewall flex is what you're going to want as well.
    Plattsburgh, NY
    2,311
    As far as I know. U should stud every single lug. And Fabio is right about the indexing. Makes a big difference to have them turned depending on how it's acting.
    Not sure if studding every lug is better for more powerful machines though, so maybe with a 125 u dont want every lug studded. For my zilla it will be every lug. Cheng shin makes a knobby tire just for ice racing. All it's lugs r slightly shifted from the rows around it so that the studs have a fresh place in the ice to grab. Just as u would do with studs in a sled track. U try to not have them match scratch lines.
    TPC TRIKES
    FSU Powersports
    RNS Powdercoating
    Nov 2010
    144
    Yeah I was thinking about the low pro tire also but having an old set of these tires is going to have to do for this year. I think I'm just going to try letting some air out for more ground contact.
    2-85 125m
    85 350x Astro
    86 350x
    80 185
    My Feedback
    You're actually gonna want to run a higher air pressure, not lower. The tires will just fold if you run them low. You want the tire nice and hard. You don't need a big contact patch at all, the studs will do their job. Do not stud the rears heavily. As tatool said, that machine isn't going to have the sac to spin those tires if they get too much bite. Then you'll go nowhere but straight. Stud the front as much as you want. You can never have too much traction in the front.
    Nov 2010
    144
    Thanks guys lots of great info.
    2-85 125m
    85 350x Astro
    86 350x
    80 185
    My Feedback
    May 2011
    eden,ny
    3,481
    not trying to hijack but I had studding Q's myself and it would be stupid to start another thread on the same topic. First is I search the subject many times and have seen the duro scorcher mentioned a few times and again tonight in another thread but I havnt seen or heard of anyone actually using them. I have a brand new one,any reason I shouldn't stud it? for the rears I have 18,19" hole shots or 20" turf tamers. Are any of them worth studding? or should I just get a new set to stud?
    Not sure about the particular tires you're mentioning Ben, but 18's work best. That's all I know. Keep in mind you'll have to re-gear if you weren't running 18's already.
    Jan 2011
    Avon, Minnesota
    641
    i heard holeshots work good when you stud them, at least my cousin did on his predator and they worked out fine
    1983 honda 200x 185 motor, Uni air filter, bassani exhaust, itp rims. FOR SALE!!!
    1982 honda 200 bigred cobra exhaust
    1989 yamaha banshee fmf gold pipes boost bottle k&n airfilter
    May 2011
    eden,ny
    3,481
    The scorcher is the tire I am most curious about. It an asphalt front tire and to stud it with the pattern I was thinking it will take 394 studs. I would think that would be enough to keep the front end planted
    Plattsburgh, NY
    2,311
    Does it have deep enough tread to have the studs not puncture?? Usually the flat track tires have such thin lugs seems like u would go right through if studded.
    TPC TRIKES
    FSU Powersports
    RNS Powdercoating
    I don't think it's a big deal if they go through a little bit. I always fill mine with Slime and they do fine.
    May 2011
    eden,ny
    3,481
    That was my plan
