86r hates to idle. Starts on first kick. Runs awesome just hates to idle hot or cold. I pulled the carb apart and it has 145 main and 42 small for the jets. So these are the factory spec jets right? It has boyesen reeds, fatty pipe, silencer and k-n. Motor has plenty of compression I tested it 180 psi cold. I am running 50-1 amsoil. I am going to rejet it what direction should I go with the jets. This is a very low hour trike that has never been taken apart other than the bolt ons.
Also where is the best place to order jets and carb rebuild kit for a factory 34mm kelein carb.
Thanks Guys
