I am thinking of replacing the carb on my 85 200s. Are the ones on ebay any good or should I rebuild the one I have? any thoughts?
just bought one for my 82 atc200 and was great out of the box, direct bolt on for me,
m.j.zee was the seller, he is a top rated seller, shipped fast, I had no issues... he has a bunch of different carbs for most trikes.
when you look at his auctions there is a Letter in the description, "L" stands for lever operated and "C" stands for cable operated... fyi
hope this helps....
1984 200ex big red1982 atc 200
it all depends what is wrong with it, first off, i would just try cleaning it, grab a can of cleaner and just clean it real good and see what happens, i usually have good luck that way if it has been sitting for a while, but if it is worn or bad, just try cleaning it first
Thanks. I have already cleaned it twice along with the gas tank. I just cant seem to get it to run right/consistantly.
You mean it runs good for a while? and then it doesn't
or you have to let it sit for a while like hot / cold cycle?
or maybe the gas cap is NOT venting? like it will run for a few minutes and die, then you walk away
annoyed for a few minutes and it will start again?
or starts again after you check the gas for the hundredth time letting air in so the gas will flow ?
That kinda stuff helps to figure it out.
Misses? stalls? and putting the choke on a little doesn't help?
Could be accumulation of rust dust under the cover that says 'cdi' on it.
I mean, I wish that a 15 minute carb cleaning is the answer or a 20$ direct replacement carb
but just thinking about intermittent spark type aggravation.
what is it doing / not doing?
Hi again Drjoe. yes all that. It seems to run well for a while and then it will just die. Sometimes it will start right back up and some times it wont. I have gotten it all warmed up ajusted the idle and then when I let it cool down and start it again it will race. I did check the gas cap and it seems clear. The gas seems to flow clear and fine to the carb so I dont think thats it.
I happened to find replacment carbs on ebay for around $25 and to me that seems cheap. Its almost worth it just to try if they are not just cheap junk.
Its a good thing I bought this thing cheap and as a tinker toy or I would really be getting aggravated.
Where is that "CDI" cover I havent checked that i dont think?
+1 on the ebay china carbs. They work great and are easier that a rebuild.
Current rides
Taurus 650 (green)
85 250es big red
82 ALT50
82 ALT50
71 QA50
93 TRX 300 FW
thanks. I think they are only a few dollars more than the rebuild kits anyway.
im sure ebay would be fine.
rebuilding the one you have now would be cheaper tho
Ride on![]()
