Results 1 to 13 of 13
Thread: 200x cam journals
    torque's Avatar
    torque is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2011
    saskatoon sk canada
    308
    200x cam journals
    i have a ported 83 200x head but the cam journals are sketchy, i want to save the head are there any options?
    thanks
    6,797
    Buy a new small end cam bushing and replace the valve cover so the top big end bushing is tight and hope for the best that its tight enough . Their should be a little play in the cam . A new cam wouldnt hurt either .
    79fordblake's Avatar
    79fordblake is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2009
    Wingo, Ky
    278
    I think some place you can get bearings that go on the big end of the camshaft. I have been wondering the same thing b/c eventually there will be no good used heads left. Maybe somebody else knows more.
    1981 Honda 185s
    DG Exhaust, Clamp on Uni Air Filter
    '85 200x carb, 200 Cylinder (SOLD)
    1981 Honda 185s
    Straight Pipe, Uni Air Filter
    200x Carb, 200 cylinder (SOLD)
    1985 Honda 250ES Big Red
    Uni Air Filter
    1986 Honda 250ES Big Red
    Uni Air Filter
    BigRed_Ryno is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2008
    Kent UK
    311
    I was debating machining it out an maybe putting some kind of bushing or bearing in there
    Sep 2007
    100mi west of Chicago
    3,582
    ^^That can be done, I have seen it somewhere, I don't remember if it was on here or not. The 2nd gen 200x came like that factory I believe
    Rob
    louisiana
    1,499
    you could buy one of those high dollar ($344) megacycle needle bearing cams,they also have a cam with bearing on just the small end $184
    Signature pic removed,becuase of no helmet.
    ^ Well worth buying. Just my set up and jig time would be hours of tramming in the journals and if there junk, what do you go off?
    We don't have an original blueprints........
    torque's Avatar
    Aug 2011
    saskatoon sk canada
    308
    thanks guys
    i have heard of the mega cycle needle brg cam, but was hoping for a cheaper solution. im going to put some stuff up for sale in the classified section to help pay for a mew mega cycle full race cam for my stroker build.
    louisiana
    1,499
    Sep 2007
    3,582
    Hey that's pretty cool, I may look into that next time I tear into my 200x top end just for added durability. Do you not have to send him the head cover to be bored?
    Rob
    torque's Avatar
    Aug 2011
    saskatoon sk canada
    308
    Quote Originally Posted by leevarnado View Post
    great find leevarnado, im on ebay daily and cant find the great pieces that you do. i will be talking to him. i just got off of the phone with megacycle and their dual brg cam with shipping to canada is 376 dollars.
    Thats a great deal, he must enjoy machining for that cost. He indicates in the circle of the cover to find the center point and must have a reamer that fits and a stock bronze bushing.
    Yes, he needs the head half and the dowel pins.
    I know a guy who was working on a roller bearing replacement for these and that's the biggest issue. If the journal's toast anyways how the hell are you going to find the centerline?
