Thread: 1983 KLT 250 fuel pump quit
    Jun 2011
    Iowa
    28
    My fuel pump went out and I was wondering if you guys think a universal pump will work? The pump said 12v 4psi on the back and O'reilly's has a Mr. Gasket universal pump that matches those specs.
    1985BigRed250ES's Avatar
    1985BigRed250ES is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Rison, Arkansas, United States
    397
    i would try it
    1985 Honda BigRed 250ES
    runs good all original
    Restoration in progress:
    1980 Honda ATC 110
    1985 Honda ATC 250SX
    1982 Honda 200ES BigRed
    1984 Honda 200S
    1984 Honda 200S parts bike
    1985 Honda ATC 110
    1983 Honda ATC 110 parts bike, runs but smokes
    Feedback link: http://www.3wheelerworldforums.com/s...ad.php?t=95258
    Jun 2011
    Iowa
    28
    I put the fuel pump in and I am running really rich, I have a had time starting it because it pumps so much fuel. The ratings on the package say 4-7 psi and 35gph. I was thinking about putting a fuel pressure regulator on it. It costs thirty dollars and has a fitting for 4psi exactly. Or I could exchange the pump for the Mr. Gasket low volume pump which is 2-3.5psi and 42gph. Which I thought was weird it flows more gph but is less psi. Definitely looking for some input on this one. Cause the regulator is thirty bucks and the other pump is forty five so its gonna cost me about the same either way.
    Jan 2011
    Brazil, Indiana
    2,087
    If it is going to cost the same I would go with the factory designed one. That way it dont look like something bcredneck built. (he cobbles crap together with whatever he has lying around, in case you didnt know)
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    May 2011
    eden,ny
    3,481
    if its the mr gasket regulator dont waste your money. if you use a regulator buy a holley they are 45-50 bucks but it can be set as low as you need. the best option I think is if you can tap a fitting into the intake and use a vaccum opererated pump like found on a snowmobile.
    Jun 2011
    Iowa
    28
    I can't find a stock pump to buy anywhere, at least not an electric. I've got a vaccuum line in the intake that someone had plugged with a screw so I wonder if it originally had a diaphragm style pump and some one switched it. So far even with a smaller pump I can't get it to start. It ran great Friday and Saturday with the larger pump and then Sunday and today it got pretty cold here so I don't know if that is making starting it so much more difficult
    397
    we have a prairie 250 kawie and it has an electric fuel pump doesnt make much noise, might hear a "click" some but other than that you dont even know it has one. what i am getting at is, I think all the kawies had electric pumps on them. I think the 2psi pump would probably work best.
    1980 Honda ATC 110
    1984 Honda 200S
    1985 Honda ATC 110
