something is wrong and im running out of ideas
over thanksgiving break i was helping my uncle fix his honda atcs. started with the 200s. he said that he was able to ride it but when he stopped and turned it off the carb would over flow. i took the carb off and cleaned it with an air hose and put it back together. tried to start it up and it was a no go. the gas was spitting out into the air filter box so i was getting gas (choke was on). put the air filter box cap back on and tried to start it still nothing. checked the spark plug and it was wet. hooked the spark plug to the cable and my bro pull started it to see if we had spark. SP worked fine. then we attempted to push start the atc. a few times up and down the driveway and still nothing. near the last try if fired and ran in second around the yard. full throttle sputtering and spitting about 10 miles an hr. then nothing and wouldnt start again after. as for the honda atc 70 i drained the bowl and cleaned the spark plug.cleaned the gas valve where the screen is. took a few pulls to get it started. raced a little then idled down to nice hum. now and then would choke up and idle funny then back to normal. every time i gave it some throttle the rpm would drop and it would slowly die. as soon as i let up it would return to normal idle. almost as if it was not getting gas. FYI the carb on the 200 was rebuilt. also hes in nj so gas down there is junk. we also tried fresh gas in the 70. still no success.
dump a little gas down the spark plug whole.....she'll start.
