Bought it a few weeks ago and haven't ridden it yet because I have learned over the years that most people are lazy,so I started tearing into it to get it ride ready:
cleaned re-lubed adjusted the headset bearings.
adjusted the valves.
stuck my XR650L baffle in it until I can replace it with something else.
made a case saver for it.
made a wheelie bar (mainly just for safety as of now-will replace.
adjusted the decompression release (It was so far out of adjustment it was basically non-functioning).
bled the brakes, (looks like it hadn't been done since the bike was new).
re-greased the swing arm,
re-greased the rear shock pivots.
fabricated a rear chain guild.
adjusted the chain.
lubed the switches on the handlebars.
cleaned out the tank.
replaced the fuel line.
lubed the throttle cable/clutch cable.
lubed rear brake pivots/linkage.
lubed clutch lever/front brake lever.
lubed kick start pivot.
other misc stuff...
still needs some stuff replaced but I want to go ride it and see how it goes...
but have never run one on any of my trikes or the need , you gotta get that 350x out on the trails ,you will love it !!!!
