Results 1 to 7 of 7
Thread: tri-z rings
    Jun 2011
    southern california
    125
    tri-z rings
    so i need a set of rings but its kinda hard to find the right ones and wanted to know will any other rings fit or can i use the wiseco with the stock piston
    May 2008
    Tenn
    548
    Seem I read a post on this subject and it wasn't recommended to mix the two. Might do a search but it will take a little time to read through the search finds.
    Just-Tri-It
    :Trikes Owned:
    1985 Tri-z's 3
    1986 Tri-z
    1984 YTM 200ERN 1
    osoyoos bc canada
    1,057
    wisco and stock rings are almost always different some times there are even more of them i fixed a cr 125 with a wiseco piston that had two rings and we bought stock rings and there was only one ring and it wouldnt fit in the grove
    Jun 2011
    southern california
    125
    yea i tried searching for it cuz i do remember seeing something like that a wile ago but came up short so was hoping that some one could just give me a quick answer
    but i did find some on ebay and hopefully these are the right ones http://www.ebay.com/itm/180441512997...#ht_500wt_1180
    Tucson
    1,652
    No you can not switch rings between the two pistons. Do you know what piston you have? Size of piston?
    Jun 2011
    southern california
    125
    as far as i know its all stock but im not really sure how to tell the diff
    Southern MN
    1,875
    Measure the piston with a caliper at minimum to tell what size it is. You can use a regular US standard caliper, if its not digital or mm, divide the number in inches by .03937 and you will get the piston size in mm's. I believe you can use Sudco or ART rings on a stock piston, as both the stock piston and the two listed are cast pistons, where as wiseco is forged. Good luck!
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
