Thread: Where to buy ice studs,and how to install?
    1,641
    I need to get some studs for my front tire for ice racing.Where is the best place to buy?What is the best tool to install them?My rear tires already had them in but don't think they are Kold Kutters.They are silver with big washer.Any ideas what brand they might be?
    Michigan UP
    1,005
    I gat most of my stuff from a local dealer, almost all of them can order from Parts Unlimited. You may have to check with your local racing rules to see what you can and can't use. The ones in the rear tires might be sheet metal screws.
    I had a Banshee a few years ago with 1 1/4 inch snowmobile carbide studs in the rear tires. I don't remember the exact amount in each rear tire but it was somewhere around 40. They looked like pissed off porcupines lol. My buddy has the quad now and unbelievably those studded tires have never went flat.
    Oct 2011
    Highland Park IL
    39
    I use a drill with a 1/4" adapter and socket. Adjust the clutch on the drill so you do not over tighten. I would run kold kutters on all, here is a link I found-
    http://home.comcast.net/~atc330rrider/iceracerpage.htm
    Plattsburgh, NY
    2,311
    kold kutters as well. tighten them just until they snug the lug, not squish it.
    TPC TRIKES
    FSU Powersports
    RNS Powdercoating
    sbjones73's Avatar
    sbjones73 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    wisconsin
    414
    over air the tires then run the studs in, then air them down to riding pressure, so they will hold air better.
    good luck
    84 250r gone,
    87 suzuki lt250r trail machine, gone to fund ice racer,
    85 250r ice racing project started !!!!!!
    Terryville,CT
    1,616
    easy just very time consuming! about an hour or so a tire!
    2- 85 250SX's
    1- 85 200X
    3-ATC 70's
