Results 1 to 7 of 7
Thread: Another ATC70 Not running right (Won't rev very high)
    tyman's Avatar
    tyman is offline Just Too Addicted Arm chair racerJust too addicted
    Jul 2006
    Bedford, Pennsylvania
    458
    It's a 79 ATC70 Stock engine. Recent timing chain, valves, piston/rings and points/condenser.
    The points are set perfect and in spec, the valves are correctly adjusted, the timing chain is on the correct tooth, the carb has been rebuilt and cleaned, the plug is brand new and it has excellent spark. It rev's to maybe 2/3 of what my 83 atc70 does and it just doesn't have any pulling power. It also gets an occasional stutter to it when holding the throttle wide-open. I replaced all the gaskets and spacers from the carb to the head and have ensured their are no leaks.
    Any ideas?
    86 200x
    72? US90
    79 ATC70
    83 ATC70
    84 ATC70
    Oct 2007
    Minneapolis mn
    4,067
    Main jet dirty, or incorrect size? (I have had "moose" carb kits where the main jet was labeled correct size, but hole was greatly larger...)
    Terryville,CT
    1,616
    bad rings? check compression
    2- 85 250SX's
    1- 85 200X
    3-ATC 70's
    Pacific NW
    4,255
    x2 with everyone above.
    Does it have a slow jet?
    I know it's 'slow' but can hang them up off idle too.
    Does it have a spark advance plate under the points?
    They love to get stuck and not rotate / return easily.
    OHIO
    2,857
    I know you said points were spot on but it sure does sound like ignition problem?? I have yanked my hair out and drank a lot of beers fighting the 70 points at times. Maybe double check em? What type of air cleaner?? Stock??
    tyman's Avatar
    Jul 2006
    458
    stock air cleaner. The compression is good. Carb was cleaned, but i could try it again. And spark advance plate? Don't think it has one. points dim right at the F mark. brand new points/condenser so they're spot on.
    86 200x
    72? US90
    79 ATC70
    83 ATC70
    84 ATC70
    Nov 2002
    Connecticut
    76
    How about a clogged muffler. Been down that road before.
