Lifan key switch partially installed. No modifications required to mount the switch to the dash plate. Still have to do the wiring. Hoping it just plugs into factory harness. Have to go back out and pull headlight to get at the harness. Figured while I was inside for a few minutes I would post some pics for you that may be interested.
Close-up of switch in dash plate.
Backside of switch. Tight squeeze but it just barely makes it.
Dash plate back on the Trike.
I think I may want to fill in the lettering with jb weld or something and paint it up. Then I can line it up with the stock ignition lables on the dash plate which could use fresh paint as well. Is there a better way to fill indented lettering on a chrome or stainless (guessing it's chrome) surface???
So this is where I'm at...
After messing with different wire positions by guessing, I got it to start fine but no lights would come on. I came inside and searched for about half an hour before I found something to go on by a similar switch on a site called Hooper Imports. Color codes are as follows respictively.
Hooper Imports product listing info for similar Lifan Switch -
Continuity for OFF is GREEN to BLACK / WHITE STRIPE
Continuity for ON is RED to BLACK
'84 Honda 125m Manual Wiring Diagram -
Continuity for ON is RED to YELLOW / RED STRIPE
I wired it this way -
Switch GREEN to 125M GREEN
Switch BLACK / WHITE STRIPE to 125m BLACK
Switch RED to 125m RED
Switch BLACK to YELLOW / RED STRIPE
With this configuration...It starts with the key siwitch in the OFF position. Turns it off when switch to ON but the Neutral light now works and goes off when shifted. It almost seems like the headlight hi / lo is reversed. I can't tell for sure though. Any electrical gurus know which wires I may have crossed? I'm just happy to have made some progress.
Update again -
So I went back out late last night when the wife went to bed. Tried a few more configurations.
I basically switched the solid colors off each other in their respective continuity groups first with OFF, then with both at same time then with ON only. I lost lights on two of them again. And one switch in wiring seemed to do nothing.
I'm almost thinking the Lifan Continuity info is reversed? You wouldn't think wiring a simpre 4 wire / 2 position switch would be this hard. Throw in the Honda wiring schematic and it's a nightmare. LOL.
in the batch.
