Results 1 to 12 of 12
Thread: little 90 just won't idle - tried everything
    mgenest is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2007
    NH
    204
    Well, just like the title says. I have tried everything to get my 77 90cc to idlle but it won't. I even went so far as to remove the carb from my other 90 that runs mint and put it on but still - no idle?? Both bikes are stock.. I tried to advance and retard the timing as well but did not seam to help at all.
    Any suggestions are greatly appreciated - thanks in advance..
    Bayville N.J.
    73
    check for an air leak at intake manifold also check valve adjustment
    Louk
    Nov 2008
    MI
    141
    Try new points. I have many of the US90 and replacing the points has done wonders in how they run.
    6,813
    Also check your compression .
    Pacific NW
    4,255
    I think I remember the spark advance plate on one of mine was stuck
    It should be a spring loaded plate behind the points that's supposed to rotate
    a little as the engine revs and return with 2 little springs.
    Drove me nuts for weeks.
    Do you have a manual?
    May or may not be in there however.
    EZ to clean/fix, no special surprises except for flying return springs
    Mar 2007
    NH
    204
    thanks guys, the points are brand new as of last week. The spark advance plate on mine seams to be working. Although, When I take it out is seams sloppy, like the springs are worn?? Not sure if this is normal or not.
    Nov 2010
    Buffalo
    41
    did you check your valve adjustment? how does your plug look?
    Trikeboss's Avatar
    Trikeboss is offline At The Back Of The Pack Arm chair racerFirst time rider
    Duluth Minnesnowta
    166
    Im having the same problem with my 110...If I give it a tiny bit of thumb it will "idle" so im going to try and adjust my throttle cable a bit so its giving it a very small amount of gas...still not sure if that is even possible but im going to try it....
    1982 HONDA ATC 185s
    1982 HONDA ATC 110
    1985BigRed250ES's Avatar
    1985BigRed250ES is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Rison, Arkansas, United States
    397
    turn you r idle up a little.
    1985 Honda BigRed 250ES
    runs good all original
    Restoration in progress:
    1980 Honda ATC 110
    1985 Honda ATC 250SX
    1982 Honda 200ES BigRed
    1984 Honda 200S
    1984 Honda 200S parts bike
    1985 Honda ATC 110
    1983 Honda ATC 110 parts bike, runs but smokes
    Feedback link: http://www.3wheelerworldforums.com/s...ad.php?t=95258
    Mar 2007
    NH
    204
    you know whats funnny, when I turn up my idle and rev it, it does not want ot turn back to idle... Just high idle.. Very bizzare.. I am going to try trikeboss's method of adjusting the cable. Let us know if that works.
    397
    throttle cable can be a problem, also check for any leaks in the intake.
    1980 Honda ATC 110
    1984 Honda 200S
    1985 Honda ATC 110
    Mar 2011
    oswego county ny
    111
    that should work for your 110 and his 90 just turn the screw coming out of the top of the carb if it has one if it dont you should be able to adjust it where it enters the throttle body and if its not there there maybe a section of the cable that iss adjustable and once you have it idleing with that use the idle screw to fine tune the idle
