Thread: Tecate and an LED headlight
    Crest California
    3,014
    So it's not the brightest light in the world, nor is it easy to find a mounting location using the included brackets, BUT it does put out a lot more light than a 55w incandescent bulb.
    Camera is crappy I know, but that is one, 110mm work light from DDM Tuning:
    http://www.ddmtuning.com/Products/LED-Work-Lamp
    I plan on buying another one for a dual light setup. From the looks of things it's totally acceptable for riding at night, lot better than the stock headlight, and at just shy of 1 amp of current draw (website says 1.25 amps, I measured about 0.98 amps). Even at high speeds it seems like it's appropriate, and it's just one light!! Two should be even better, although it's not a spot light so much as it is a directional flood light.
    For $35 you can't go wrong, not to mention it's only around 1 amp of current draw at 12.9v. DDM Tuning does have higher output lights but these work great. Just thought I would share my findings.
    LED obsessed
    2015 Yamaha FJ-09
    South Wales, U.K.
    525
    got of any pics of it mounted on the t3?? lets see the beast?
    If it ain't sideways......what's the point!!
    86' Honda Atc 250R - under restoration
    10' Polaris Outlaw 525s - my XC race quad
    05' ATK 640 "Cannondale" xc racer
    00' Banshee 350
    Crest California
    3,014
    Nothing special, and nothing is permanent for now (hell it's even wire nutted into the harness ).
    Still trying to figure out a good place to mount it. May have to bend up the mounts they included to get it to fit.
    LED obsessed
    2015 Yamaha FJ-09
    May 2009
    monroe, Louisiana, United States
    948
    that looks pretty good man
    Crest California
    3,014
    When I get some free time i'm going to try and make a clean harness to install, instead of using lots of tape and zip ties
    LED obsessed
    2015 Yamaha FJ-09
