Thread: Pulling a Hub
    Sep 2011
    MD, USA
    6
    Pulling a Hub
    I need to replace the rear sprocket on the '79, 110. How is the best way to pull the hub? I'm sure it'll be rusted tight with age.
    May 2011
    eden,ny
    3,481
    spray the hell out of it with some pb blaster( helps if you put it on it's side for it to soak in) then smack it with a deadblow from the inside,turning the axle as you go. heat also helps. heat the hub not the axle(if you can)edit... after spraying it let it soak a few hours or overnight
    Mar 2011
    oswego county ny
    111
    it helps to leave the tire on the hub just remove the one hub bolt if you cant pull it off just tip the wheeler a bit and try kicking the tire usualy works for me
    Sep 2011
    MD, USA
    6
    Thanks ya'll. I'll try to get it off when it quits raining
