Results 1 to 14 of 14
Thread: New tri zinger plastic?
    Dec 2011
    Houston, TX
    10
    Does anyone make new plastic for the tri zinger? Also, wheres a good place to get a carb rebuild kit? Does anyone have any experience with those $30 carbs on ebay? I was thinking about getting one im guessing they use the same jets as the miks.
    Cullman,Al
    11
    You need to find some parting one out, and just keep checking ebay til you get lucky. Those carbs are copies so they should work fine.
    OK
    5,450
    DC Plastics sells a reproduction front fender. NOS or used rear fenders appear fairly frequently on Ebay. The oem front fenders are like a needle in a haystack to find.. Make sure you check the yf60 4-zinger for parts on Ebay. The rear plastic is the same. Besides plastics and the frame/front suspension everything else is the same. I have heard good things about the Ebay copy carbs, but I have never used one.
    http://www.dcvmx.com/xcart/product.p...cat=282&page=2
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    Dec 2011
    Houston, TX
    10
    Thanks for the link. I think Ill try one of those carbs. For $30 I guess its worth the try. I emailed the seller and he said they use the same jets as the mikunis
    Dec 2010
    S.E. Illinois
    1,178
    just a personal curiosity, what's your zinger's original color?
    welcome to the site.
    74 HONDA ATC 70
    Dec 2011
    Houston, TX
    10
    Its a beautiful sunspot/faded blue. If i cant find a replacement i might try that plastic refinish techniqe with the wet sandpaper. I just dont know if i would have the patience
    86R is offline New to the board Arm chair racerNew to the board
    Oct 2011
    So.IL US
    20
    Don't have my maier catalog with me but I'm pretty sure they make plastics for it.
    OK
    5,450
    Quote Originally Posted by 86R View Post
    Maier has never made Tri-Zinger plastics. DC Plastics makes a reproduction front fender, anything else is used.. or if your pockets are deep enough.. NOS which is hard to find..
    The oem fenders do clean up nice with a razor blade and some wet sanding and polishing..
    Rides:
    My feedback thread
    Oct 2011
    So.IL US
    20
    I had no idea yamaha made small ones thought yall meant zs my bad
    Dec 2011
    Houston, TX
    10
    Just searching around I found this http://answers.yahoo.com/question/in...6064552AAQSbwD I thought about trying it out, sounds like a lot less work than sanding.
    Oct 2011
    Manchester england
    135
    Good link that n61870 as linseed oil is clear it should work for most colours also. I do use the wet sanding method which when done correctly does work a treat but patience is a must.
    DONT DO QUAD ROIND HERE! Live fast or die trying
    3 wheels for life
    86' Tri z converted back from a quad
    86 Tri z in bits
    Banshee ready for the chop
    04 cr 250 with vforce
    Tri zinger
    Crf/yx140 mini motox
    Jincheng 50 for those drunken evenings in the feild
    Race van
    Shogun
    And a hot tub for after a days ride! Yehaaa!
    Fox Valley Wisconsin
    35
    I recently bought 2 front fenders from dcvmx, for 2 of my zingers, they are pretty good you have to bend the mounting tabs to make it fit right and drill your own holes. Better than nothing for sure!
    current trikes:
    84 225dx with HID
    2 Speed tri Zinger
    2 more tri zingers and 4 zinger
    I had:
    82 atc70
    80 tri moto yt125 with Dt175 topend
    35
    Good luck buying rear fenders, I'm in the proccess of buying all the rear fenders i can to have a stock pile! I bought the only 2 blue rear fenders i've ever seen off ebay within the last 2 years.
    current trikes:
    84 225dx with HID
    2 Speed tri Zinger
    I had:
    82 atc70
    Jul 2012
    Penfield NY
    660
    I found this rear fender on eBay last year. Wasn't cheap.
    "See, morbid and creepifying, I got no problem with, long as she does it quiet-like. "
    Trikes:
    1982 Honda ATC250R(in process), 1984 Honda ATC110, 1984 Honda 200s, 1985 Kawasaki KLT160(not running...yet)
    Quads:
    1990 Suzuki LT250S, 2013 Suzuki LT-Z400, 2014 Honda TRX450R SE
