Results 1 to 2 of 2
Thread: Atc 110 baffle & needle clip ?
    Trikeboss's Avatar
    Trikeboss is offline At The Back Of The Pack Arm chair racerFirst time rider
    Duluth Minnesnowta
    166
    Just wondering if anyone runs there atc 110 without the exhaust baffle?
    Also what needle clip position are you running? (with or with out the baffle)
    Im asking about the needle clip since I have a slight bog/miss but only if im going up a steep hill and want to adjust the needle to see if it helps...
    If I pin the gas before the hill it will climb it no problem but if I hit the gas under heavy load up a hill it will cut out/bog a bit...
    1982 HONDA ATC 185s
    1982 HONDA ATC 110
    Jan 2011
    Avon, Minnesota
    641
    ok all my 110s i had were straight piped lol. but one i had with stock pipe you cant take out the baffle just the spark arrestor. the baffles are inside the pipe. when mine were straight piped i was 1 down from the middle. But mine used to do that to if i would go ditch climing and doing about 1/4 throttle then it, it would almost kill. i found out it was my valves set at 0 for clearence.
    1983 honda 200x 185 motor, Uni air filter, bassani exhaust, itp rims. FOR SALE!!!
    1982 honda 200 bigred cobra exhaust
    1989 yamaha banshee fmf gold pipes boost bottle k&n airfilter
