Hey guys just thought I'd share my dyno results with ya! I made a couple dyno runs a few weeks ago and finally found the time to post my results. What I've got is an '85 ATC 70. Everything I've put into it includes
- 88 cylinder kit
- 20mm Keihin carb
- K&N filter
- 5 angle valve job 30 degree back cut valves and ported original honda head (Machining and porting done by me)
- Beatrice Cycle race roller bearing style cam
- Cobra Pipe
- Parts Unlimited chain
- Kenda scorpion tires
I've found Honda rated these at 3.5 horse and while I didn't get to dyno it stock I did dyno my '74 z50 which was about equivalent in power and that produced exactly 3.5 horsepower and 3 ft.lbs. at about 6500 RPM.
The ATC after all modifications did quite a bit better making 16 HP at 10,200 RPM and 8.5 ft.lbs. at 8,500 RPM and as you can see by the dyno chart the torque curve is pretty broad in fact it never fell off to my surprise! Like I said I can answer any questions I did all the work myself from machining to dyno runs.
'81 ATC 250r: IMS tank,Uni pod filter,Keihin PJ flat 38mm,Boyesen Pro series reeds,reed spacer w/ boost bottle,milled head,bored(.080),ported,machined CR exhaust flange,and Mugen pipe.PK +3 swingarm,2+2 axle,ITP rims,and 200X fork swap w/ polished tree.
