Thread: I need some help with my 200s can anyone help plz thanx
    Dec 2011
    my 200s running rich could it be out of time
    glendive, montana
    1,822
    well have you adjusted the carb yet? Also why do you think it's out of time,? There are free downloadable manuals in the world class help section if you need the specs for the carb
    Dec 2011
    Brookfield NH
    30
    do you know what the compression is? mine has 90lbs and it smokes, although the carb has been tuned.
    Dec 2011
    yea I have adjusted it every way possible idk Wat the compression is I know ive broke 3 handles and can pick the3 wheeler off ground sometimes
    glendive, montana
    1,822
    kinda sounds like maybe a bent valve, as well or the ebay carb. Compression listing should be in the manual. I just looked and it says 156lbs, + or - 14lbs. here is a direct link to the manuals downloadable site, your model is in there. http://www.oscarmayer.net/atc/manuals/ Timing instructions are in there, check timing, and then I would definitely look at the valves if timing is right.
