Results 1 to 8 of 8
Thread: 250R Suspension
    Oct 2009
    Ontario
    87
    250R Suspension
    Ive decided to take a brake from ridin those dirty four wheelers and start my trike back up again. With the bacl end off and then engine out Im not sure how the motor mount and the rear shock go in. Both the clymer and shop manual seem to be fairly dusty in this area. The shock is to wide to fit in the frame mount or the engine mount. I need help badly.
    Lots of Tri Moto parts for sale!
    sbjones73's Avatar
    sbjones73 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    wisconsin
    414
    year of the 250r ?
    84 250r gone,
    87 suzuki lt250r trail machine, gone to fund ice racer,
    85 250r ice racing project started !!!!!!
    Oct 2009
    Ontario
    87
    Forgot to include that. Its an 84.
    Oct 2009
    Ontario
    87
    Can anyone help me?
    Southern MN
    1,875
    Have an assistant help you. Place the engine in the frame, and put in the swingarm bolt through the frame, motor and swingarm like it should go. You should now be able to see how it goes together, unless you are missing some pieces? Why was it apart anyway?
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Texas
    137
ID:	137439 Click image for larger version.
    The engine/shock mount goes vertical, with the narrow end at the top and oriented to the rear. The top of the mount bolts to the frame bracket that also supports the front of the airbox. The front of the shock bolts to the mount holes just under that. The swingarm pivot bolt goes through the tube in the mount, the other 2 holes in the mount (front and bottom) are for engine mounting bolts. The Clymer manual has a pretty good diagram of the shock linkage.
    May 2011
    Michigan
    109
    would that mount workon an 85?
    Oct 2009
    Ontario
    87
    I replaced all the seals and bearings in the bottom end, replaced the crank and did a top end job as well. But being caught up workin on my sleds I havnt had a chance to work on her for a while. Thanks for the pictures BronocGuy ill take a look tommarow
