yes, although i forgot what its called, i'll try to find out what its called and how much it costs.
I just bought the por-15 kit for mine. Haven't done it yet but I hear it's pretty good. The kit was like $45.
there's quite a few products to choose from for sealing a tank. only heard good stuff about the por-15, but have not used it yet.
Kreem SUCKS! dont waste your money.
Current rides
Taurus 650 (green)
85 250es big red
82 ALT50
82 ALT50
71 QA50
93 TRX 300 FW
If you can get the search key to work, you will see more info than you'd ever want.
Some are 'coatings' which mean they can peel off.
por 15 reacts With the rust and is the phosphoric acid 'basis' of naval jelly.
Complex chemistry but essentially bonds with and transforms the iron oxide to something inert.
Then again, marketing is all so convincing.
I looked into marine rust issues and phosphoric acid makes the most sense to me.
I poured some on a rusty woodstove outside and it turned the rust black, like glass.
and it's still there. I whacked it with aand fresh shiny steel was 'under' it.
Radiator shops may do it right because they have to guarantee their work.
I clean mine with a pressure washer, drydrydry completely, maybe rinse with 'heet',
and then just keep them full.
No oxygen, no rust.
Or dead empty and hanging in a warm living room all winter.
worst is 1/2 full or empty with the cap on and many temperature fluctuations.. = condensation.
A million opinions for sure with no perfect answer but my next one is going to a radiator shop to be cleaned and sealed.
...I think.
or not.
thanks fellas for all the input
1984 Honda ATC200M
2009 Honda Rancher 420AT
Ya just clean the rust off instead of covering it use vinigar and salt and let it soak for a few days it will work wonders and cheap too
151 Rum?
White lightnin'?
moonshibe?
Rub Alcohol kinda takes a while to dry but heet disappears almost instantly, taking the water with it.
Still not sure what it actually does to a few drops of water in a tank tho.
I'll have to experiment with some gas in a glass jar with a little water .
I DO know that water will sit in the bottom of a tank and rot a hole right where it sits for sure.
Heck, I've even set mine on a bbq to dry them.
Cheaper is best .
I just like what my uncle said about car 'cocktails' and additives.
You can open the hood and pour them directly on the ground and they usually have the same effect.
It makes the driver 'feel' better, is all.
I think the main ingredient to methanol is,,, ready for this,,, methanol.
I buy about 12, 55 gallon drums of it a year at work.
http://en.wikipedia.org/wiki/Methanol
it works a heck of a lot better for a moisture curing agent then rubbing alcohol could ever dream of doing (and I use it exclusively in cleaning out nasty trike tanks too)
http://www.frangergas.com/jones/index.html
ok ya got me there it seems. i'm just going by the fact almost everyone around this area uses rubbing alcohol when they get water in their tanks and during the winter months when needed. i know getting and using methanol might not cross some peoples minds but anyone can go to the store and pick up a bottle of rubbing alcohol easily. also, i've never had to personally clean out a tank yet thankfully. helped plenty of friends with their tanks and never had any problems yet.
my mistake, sorry if i have given bad info.![]()
Build a simple electrolysis tank, hook it up, soak for a few days, rinse, dry with a blowdryer, and either then use POR-15 to coat it, or spray the hell out of it with WD-40.
$23 can of por-15 coat the inside and outside... worked perfect with mine and it was easy and cheap. it had huge holes and now they r gone. i por-15 everything =)
Toys:
85 Honda 250sx
08 Kawasaki KLX 110 w/143cc kit
72 Kawasaki F7 175
72 Massey Fergison ski wiz
98 Polaris 488 ss
87 VW Fox w/2.0 aba swap (1 and only)
77 Chevy ElCamino
88 Kawasaki JS-440 w/550 swap
86 Kawasaki X-2
88 WetJet 432
96 Tigershark Dayton 770
88 Kawasaki 650 sx
84 Wet Bike
84 Honda Spree
89 Kawasaki 300sx
some boats
a mountain bike with a 49cc motor on it....
