When crankshaft is indicating T my camshaft O mark is straight up top at indicator mark as manual describes. I rotate crank to T again and my cam O mark is straight down 180 from last position. My question is does the cam rotate once for every two rotations of crank? Also does anyone know
what the "index mark" looks like on the pulse generator (the part with the little cams and springs). I found the punch mark on the rotor but wasnt sure what the index mark looked like. It is possible to get the rotor 180 out. There is a small o stamped on it that can line up with the punch mark. If you install it 180 the other way there isnt any kind of mark. Thanks
