Results 1 to 7 of 7
Thread: got a used big red fork - brake housing stuck on axle shaft
    Aug 2011
    western maine
    113
    bro and i were putting on a good BR front fork last night and ran into a snag. the fork i got came with a shitty axle and a brake housing thats stuck on pretty good. to get the axle off the one of the fork shafts we cut the head off the axle since the axle is junk and the threads are FUBAR. we tried to hit the old axle out with a smaller shaft and a . after a good 20 min it was a no go. we even tried tapping on the brake housing with a block of wood and a to slide it off the axle but it didnt do anything. now its soaking in a bucket of chain oil. any ideas how to get this brake off. the brake works fine and is in very good condition.
    dump a little gas down the spark plug whole.....she'll start.
    Pacific NW
    4,255
    do you mean the front axle bolt where it goes thru the aluminum casing for about an inch?
    That MIGHT be threaded in there.
    If your search key doesn't work, let me know and I'll see what I can find.
    I DO know that at some point, I was warned about those and walk around all of mine a couple times
    a year and hit those with some penetrating oil for the day it's MY turn to take one apart.
    Aug 2011
    western maine
    113
    hmm never thought about it. on my original axle shaft there are no threads except at the end where the nut goes on. the brake housing is about an inch deep where the shaft runs through. on my old fork before i bent it really bad a few years back the old brake housing looked dfferent. i know that for a fact. this one though could be aftermarket back in the day. ill giive it a shot when i get home.
    swifty's Avatar
    swifty is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    sabula iowa
    381
    what year big red you got?? 85-87 is threaded!! and 90% of the time the axle is seized in the threads
    ACT NOW THINK LATER!
    current trikes owned
    minty 86 250sx my rider
    pauter flat track framed 110-123cc with custom goodies
    pauter mx framed 110-123cc with aftermarket goodies
    joker framed 90-108cc with front suspension
    2007 artic cat DVX 400
    dickson sprint framed 73 green us90 with 110 engine
    Pacific NW
    4,255
    Quote Originally Posted by swifty View Post
    THANK you mr swifty.
    I truly AM worried about the day I get to take one apart which is why I hit 'em all with
    liq wrench every time I think about it.
    I guess the threads come out with the bolt on these sometimes IF the bolt comes out at all.
    Aug 2011
    western maine
    113
    used fork is from 83-84. and those axles have no threading near the head, only for the nut.
    swifty's Avatar
    sabula iowa
    381
    ive had to heat the sh%t out of the last 2 i did and use a 4 fot breaker bar and go back and forth in very little turns to get them out without the threads striping or the bolt breaking
