Results 1 to 8 of 8
Thread: 85 350x clutch and spring suggestions
    SC
    67
    I hate to do it after seeing the hundreds of posts on this...
    I need some advice on hd springs and clutch for my 350x. Clutch was installed almost one year ago during build and is already starting to slip. I thought I'd go ahead and put the nastiest springs I can find in it along with a good clutch.
    Suggestions??
    Well, you can get springs with as much holding force as you wish.
    What clutch did you install?? An EBC or El-Cheapo EBAY clutch??
    I run OEM or Barnett with Barnett springs and I am a heavy clutch user.......
    Unless you have allot of motor upgrades, the aforementioned clutch will do the job fine.
    baycitysteve's Avatar
    baycitysteve is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2011
    baycity
    199
    machine the presure plates and get a extra fiber and metal disk in there ,that and good springs really help
    ss350x
    Apr 2008
    NW, IND.
    842
    Haven't had any problems with my Vesrah Kit and it came with HD springs. I lightly scuff my steel plates and soak my fibers in oil before install.
    80' Honda CR80R
    78' Honda XR75
    77' Honda CT-70
    74' Honda CT-70
    75' Yamaha GT80 Enduro
    76' Kawasaki KZ900
    73' Kawasaki H1-500
    76' Kawasaki H1-500
    SC
    67
    I'm not sure what clutch I'm going to use this time around. I just know I don't want to replace it again next year. It has a slight bore, stage 2 cam, nothing major. A LOT of compression.
    I mainly trail ride...
    Quote Originally Posted by beets442 View Post
    How long have you had it and how often do you ride?
    Apr 2008
    NW, IND.
    842
    Its been in for three years. I ride trails and track, med hard rider.
    80' Honda CR80R
    78' Honda XR75
    77' Honda CT-70
    74' Honda CT-70
    76' Kawasaki KZ900
    73' Kawasaki H1-500
    76' Kawasaki H1-500
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    All I have used is Barnett for everything, and I'm hard on the clutch...no issues as of yet,,
    TF 07,08,09,10,11,12,13,14!
    SC
    67
    I read some good stuff about the Vesrah, guess I'll try it out this time around. Thanks for the advice guys.
