Thread: CR85 Caliper on 200x?
    rodeofan5656's Avatar
    rodeofan5656 is offline Girlfriend wishes I'd last longer than 8 seconds Arm chair racerAt the back of the pack
    Dec 2011
    Park City, KS
    389
    ive read a few forums about this, but cant post a reply yet. the 1986 200x im wantin to trade my truck for doesnt have brakes whatsoever. whatre the steps you take to put the CR85 caliper on? do the cables from the stock caliper hook right up to it? what year(s) CR85 calipers should i try to find? thanks for any help you may have
    Dec 2011
    Park City, KS
    389
    also, does the disc need to be changed? i just wanna find out all i can before i take the chance at payin for the caliper. i found a few around $25 on ebay
    Jun 2009
    Leander TX
    2,217
    Well, I'm not sure what the 86 200x had originally for a rear caliper but, if it's like the 1st gen 200x and 350x, any CR80 - CR85 front caliper will bolt on.
    You lose the parking brake when using the CR caliper.
    The brake line bolts up in the same place.
    You need the ATC caliper mounting brackets and stays. One of my 84 200x has the CR caliper and I also have one for my 350x when it gets put back together.
    I bookmarked it
    http://www.3wheelerworld.com/showthr...r-83-85-200x-s
    Dec 2011
    Park City, KS
    389
    so the CR80 will bolt right to the 200x bracket? which brake lines do i use, the 200x or the ones for the CR? and is there a swap i can do on the front like this? thanks
    Dec 2011
    Park City, KS
    389
    is there a master cylinder/hydro line from another bike thatll fit on the stock 200x front caliper? ive got the front caliper, but no other hardware
