i have problem with the carb on my atc 70, it runs for 2 seconds and stalls. it seems like it is running out of gas but, it has plenty of gas, i just replaced the gas lines and both jets are clear. any thing im missing?
have you rebuilt the carb at all? could just be the float.
yes i have. three times actually lol i think the float is sticking though
Is your air screw set correctly? Did you check the gas flow out of the petcock? Just thinking out loud
if you think your float is stuck or there is a vapor lock between the gas line and the carburetor, open up the drain screw
at the bottom of your carburetor, then turn the gas on. If your float isnt stuck gas will pour out of the petcock at the bottom
and you will know that you have gas in the carb. And if it overflows after you turn in the drain screw the float is stuck open.
Good Luck!
thank you guys, i got it running and found out it needs rings, but luckily i have a barn full of motorcycles from the 70's and other three wheelers lol
Selling any barn items? He he
'79 Honda Odyssey
'81 Kawasaki KLT 200 (highlighter)
'85 Yamaha Tri-Z
'82 Suzuki GS450L
'05 Suzuki Eiger 400
what are you looking for?
84 250r master brake cylinder assembly and rear caliper
'79 Honda Odyssey
'85 Yamaha Tri-Z
'82 Suzuki GS450L
nope no 250r stuff
well, i dont know anythin about those small trikes, but i know my 200x does that when the choke is left on. ill start it, it runs awesome. then a few seconds later-dead. like Tippmann98, im just thinkin out loud
1986 Honda ATC200X
2005 Yamaha Road Star 1700
ToyHauler- 1998 Ram 3500 5.9L Turbo Diesel
