Results 1 to 7 of 7
Thread: 200x Zoom Zoom ebay carb
    Manitoba
    536
    Just wanted to post that I installed a carburetor purchased on ebay from Zoom Zoom on my 84 200x. I compared the dimensions to the old carb, and it looks like it is the same size. Slight differences in the drain tube(s) and bowl. Starts first kick now, hot or cold, and run beautifully. I may have gotten lucky, but it seems they set up this replacement carb right. Weather here isnt conducive to comparing the top speed with the new carb, but it sure idles smoother and starts easier.
    84 200x
    Mar 2011
    Ohio
    236
    I've been reading about these and I'm ready to pull the trigger. From what I'm reading it seems like 90% of people have had great experiences. My only concern is I have a Honda 200x with 200s engine. I was planning on buying the 200x carb so it'll line up with the air boot correctly. Are there any major differences between the engines that will affect how my results?
    Sep 2007
    100mi west of Chicago
    3,582
    I've had great luck with mine, been running it since April 2010. It always idles nice unlike with the stock carb which was erratic even after rebuilding it.
    Rob
    Manitoba
    536
    I can report back after a good winter trail ride that the new carb is working great. Snowy trails are a lot of fun, but I couldn't get enough traction to do wheelies.
    84 200x
    Mar 2011
    Ohio
    236
    My Zoom Zoom carb out of the box is not working well. I adjusted the pilot screw to 2 and 1/4 turns out like it should be but it has an erratic idle and doesn't run as strong as it should. I have to leave the choke half way on otherwise it stalls out.
    Then it's too lean....... Or your letting too much air in.
    Manitoba
    536
    Mine was set at 3 turns out from the factory, and it is running great in that position. My old carb used to pop and bang the exhaust when I let off the throttle. This carb revs smoother and no lean popping when I let off the gas.
    84 200x
