Results 1 to 15 of 21
Thread: #11 got a new front end!
    it was a long morning... but it came out of surgery ok... actually better than ok.. heres how I started off..
    Attached Thumbnails Attached Thumbnails 1320530293953.jpg   1322413452279.jpg   1322414606275.jpg   1322414607560.jpg   1324078157168.jpg   1324134905438.jpg
    then we got serious... first thing with the Howser bar clamps the aluminum ferro has to be trimmed to 1'' 5/16 and the thickness of the rubber shoulder has to be removed from one bushing. Should look like the 4th pic just inside the rubber on both sides. Tighten em down and cut off the extra thred's.
    Attached Thumbnails Attached Thumbnails 1324134907254.jpg   1324134908122.jpg   1324137818437.jpg   1324137816780.jpg   1324144583306.jpg   1324137817655.jpg
    Sep 2006
    Northwest Indiana
    1,893
    Nice front end...
    Picture them trips anodized:naughty
    then it go's from coffee to beer QUICK! go to mount the triples and the stem hole has a step in it not allowing it to fully seat on the lock nut. Rat Tail File to the Rescue! pic 6 is what the Howser clamps should look like.
    then I took my retired Aussie duner plate and "many memorable races on that plate" used the fork stand offs with a DC plastic white tecate plate , trimming with a new razor.. a few rivets.. there was plenty of plastic on the plate to custom trim it ,,I left the top corners to protect my speed bleeders but cut the center out to allow movement of the cables...
    Attached Thumbnails Attached Thumbnails 1324141498661.jpg   1324144579910.jpg   1324144581678.jpg   1324144580875.jpg   1324144582496.jpg   1324144584088.jpg
    1324134906428.jpg   1324149314673.jpg   1324154034397.jpg   1324150709238.jpg   1324154101359.jpg
    Quote Originally Posted by tecat-z View Post
    Nice front end...
    can you do em gold? haha who am I kidding I scratch every thing i own..LOL
    end Pics after hackin up the tecate plate.. GIT IT! The chunks of plastic I had left over I uses for backers for my rivets.
    Attached Thumbnails Attached Thumbnails DSCF8013.jpg   DSCF8003.jpg   DSCF8004.jpg   DSCF8005.jpg   DSCF8006.jpg   DSCF8009.jpg
    turner,Me.
    53
    Man,That thing look's so awesome! Great job.
    bigredridr's Avatar
    bigredridr is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2011
    shoharie NY
    273
    very nice what did you use for the forks? any mods for the caliper bracket?
    85 1/2 Tri-Z
    85 350X
    85 250ES
    audioworks04's Avatar
    Oct 2008
    Kansas City, KS
    332
    Appears to be Jason Hall's whole set up using KTM 85sx forks, caliper and rotor, Jason includes an adapter for the rotor.
    86 atc250r stock sand only
    88 NX250 mint rainy day
    Quote Originally Posted by audioworks04 View Post
    well yes and no.. this is one off ,, tripples and axle yes,, 85sx forks yes. 525xc duel piston caliper ,, stock rotor. re drilled and re taped. these forks came from the first set of triz inverts ever back in 05! the lower fork leg has been cut. so major fabrication has been called in. to make every thing line up with jasons stuff... YES HALL'S PEFORMANCE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Plattsburgh, NY
    2,311
    is the tri-z steering stem the same diameter as a 250R? i will be doing a similar front end on my '86 R but with cut down CR125 forks. just wondering how much is the same on a tri-z.
    TPC TRIKES
    FSU Powersports
    RNS Powdercoating
    Quote Originally Posted by Tattool23 View Post
    Jason makes the tripples useing the 250R stem also. ya there diffrent.
    861
    That really looks trick.Great job. I got some CR forks for my 86R I want to do some day.
    ]1986 ATC 330R
    Jul 2011
    Lilly PA
    1,480
    Looks great Raffa!!! GIT IT #11!!!!
    Just sit back and chillaxx
    Quote Originally Posted by 84t3 View Post
    do you remember that picture from the hill climb? LMFAO! too funny!
