Thread: The Subaru Thread
    Oct 2011
    Glamy's place
    95
    The Subaru Thread
    This thread is for you Subaru guys. Post up you car and any mods you have done
    Jun 2003
    Lake George, New York
    1,732
    Here's my 06 STI.
    Mods;
    Engine/Power
    EcuTek RaceRom tuned by John Visconti
    ACL Bearings
    Cosworth Rods
    Cosworth pistons
    Cosworth head gaskets
    ARP studs
    Gates HD timing belt
    11mm STI oil pump
    Killer B oil pickup tube
    DW 850cc Injectors
    HTA Green Turbo 3" inlet 8cm
    TGV deletes
    Agency Power Hard 3" inlet
    GMS thick gaskets
    Perrin BIG MAF Intake
    Perrin stealth FMIC
    Perrin Recirc BPV
    Perrin EL header
    Perrin Coolant Catch Can
    Ball Racing SS AVCS/turbo oil feed line
    Grimmspeed EWG Upipe
    Tial 44mm EWG
    Grimmspeed 8mm Penolic intake manifold spacers
    Invidia catless DP
    Cobb 3" CBE
    Hallman MBC
    ACT 6 puck clutch
    ACT streetlite flywheel
    OMNI 4 bar MAP sensor
    Crawford AOS
    Deka ETX14 LW battery
    Suspension/Handling
    BC Coilovers with rear extenders
    Whiteline Rear camber bolts
    18x9.5 Rota T2R
    235/40/18 Federals
    Black Wheeltek lug nuts
    Hawk HPS F&R brake pads
    Kartboy short throw shifter
    Kartboy Front and rear bushings
    Group N Pitch mount
    Group N Rear diff mount
    Group N Engine mounts
    Group N tranny mount
    Interior/Exterior
    STI limited replica front lip
    STI limited console
    Hella supertones
    Killer B radiator shroud
    DIY red grill stripe
    JDM Hazard button
    Cleared/painted headlights
    Red LED running lights
    White LED interior lights
    20% tint all around
    04/05 taillights
    Rally Armour flaps
    Innovative wideband
    STRI Boost, Oil Pressure, EGT 60mm Gauges
    ATI clock pod
    Bride Shift boot
    Bride E-brake boot
    Euro Plate
    Weight reduction
    Deka ETX14 battery
    Front subframe
    Perrin front bumper beam
    Windshield washer reservoir
    Several brackets under the hood
    Inner fenders/plastic under trays
    Rear seat clean out
    Complete trunk cleanout (spare tire, jack, tools, intercooler sprayer)
    ACT streetlite flywheel that was custom milled down
    It weighs 2795lbs with half a tank of gas. A little over 500lbs lighter than stock Makes between 450-500whp on pump gas.
    My family has always been into Subarus. I've had a couple, but nothing to crow about.
    I'd just like to add that you can't buy a better car than a Subaru.
    NEPA
    7,051
    That is a stunning ride airman.. I don't own one,,but the STPR is 35 miles from my house,,try to go every year. I have had the pleasure of meeting and watching some incredible vehicles and talent over there,,mostly Subies. Millen,Chenoire,Buckham,Pastrana,Deegan,Bartram, Block, Mirra,,,on and on.. Great times out in the woods. Someday I Will test drive one of these,,and probably bring it home! As much as I love my big trucks,I love little cars too?! Love the handling. Had a Suzuki loaner last service at the GMC dealer.{ Yes,,I do my own services,,it came with 3 free washes and services}.. Wifie said Noone should be allowed to have that much fun!......I was grinnin.
    STL
    3,560
    Nice sti! I sold my 06 WRX TR a few months ago.
    MODS:
    VF39@ 19.5psi
    open source tune
    big Top mount IC
    3" Tanabe turbo back exhaust
    3" up pipe
    hallman mbc
    prosport oil and boost gauge
    Kurt hitch for my trailer
    Grimspeed turbo heat shield
    hood scoop wind deflector piece. No clue of any part names related to scoobies at this point lol sad.
    And heres my other baby. 91 MR2 Turbo. on its fourth turbo motor
    Gen3 3sgte
    18psi
    540cc injectors
    255lph wlabro fuel pump
    Greddy EBC
    3" KO Racing exhaust
    sidemount IC
    Street Brawler 50 Trim turbo kit w 38mm external wastegate
    kurt hitch for towing bikes to TF like a damned fool. Above pic is from TF2011
    spec stage3 clutch
    Fidanza Flywheel
    LSD tranny
    16x8.5 Kosei's with 245's on the rear
    93 turbo brakes with Carbon Kevlar pads and SS brake lines.
    upgraded remachined pinion gear to decrease lock to lock turn of steering wheel
    greddy turbo timer
    Sparco boost gauge
    too much else to list, I have been through alot with this car. It had a stroker motor that made over 300rwhp 2 years ago with a Power FC engine management system.
