Thread: xr80 clutch problems
    Dec 2009
    the ville illinois
    477
    My son has a 06 xr 80. It dosent get rode alot and after setting a couple weeks, sometimes the clutch sticks. Its not the cable, everything there moves freely.It seems like the fibers are sticking to the steels.After starting it in gear and riding it around for a min. it frees right up. Could the wrong oil be doing this?
    6,786
    Very common prob . the bike just needs to be used more often .
    Quote Originally Posted by racer....X View Post
    300rman's Avatar
    Nov 2007
    toledo
    2,667
    Try running Rotella in it. I have a 1980 XL80, and the clutch never sticks, even after sitting for months. and the clutch also grabs fine, so its not worn out or anything
    Dec 2009
    the ville illinois
    477
    Cool.....thanks shortline. 300man I think it has rotella in in now, but I will change it tomorow and make sure it does.
    stevensj13's Avatar
    stevensj13 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2011
    Willow Springs, North Carolina, United States
    338
    Those XR80s are bulletproof. Mine leaks oil from the shifter seal (common problem) and the valves chatter worse than someone shaking a coin purse but it just keeps running! I add whatever oil I have around no matter whats in it just to bring the lever back up to where its supposed to be. I never had the clutch stick though. Infact I broke the chain on it and let it sit for 2 or 3 months with gas in it and everything, added oil, fired up first kick no choke. Clutch worked fine and didn't stick.
    My baby - 1984 Honda 200X, Clark Desert Tank, Supertrapp exhaust.
