Thread: Looking for a little help need a carbouretor for tri-z 250
    Aug 2007
    Paris tx
    16
    Cool Looking for a little help need a carbouretor for tri-z 250
    Hey just bought my first tri-z needless to say im pumped but the carb is shot, i need recomendations on what model carb to buy for it, oh and its completly stock if that helps... Thanks and will appriciate any help i get!!
    zzmegad's Avatar
    zzmegad is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2008
    North of Chicago
    317
    everyone likes the keihin pwk carbs, but they are about $250-$300 new by the time your all said and done. thats what I'm saving for, my Z carb is all pitted and nasty, but still functions ok
    Aug 2007
    Paris tx
    16
    yea but what mm carb do i go with
    zzmegad's Avatar
    Nov 2008
    North of Chicago
    317
    i was going to get the 38, some people like the 39, others the 36. I think the stock size is 32??
    Sep 2006
    Northwest Indiana
    1,893
    A great all around carb is the Mikuni VM34. It's a round slide design that is pretty much a direct replacement for the oem carb. Many people balk at the thought of using this style carb, but my experience with them is very solid with a stock to mildly prepped 250cc engine. They can be had new for right around $100. Alternate jets are very easy to locate too. You will gain a bit of mid/top power too. Don't mess with old worn out carbs. They only cause grief, and cost performance from idle on up.
    Salt Lake City
    48
    Quote Originally Posted by tecat-z View Post
    That's some very good advice that I would agree with. I know a lot of people will also use a flat side keihin off of an 86 R or any TRX250R which are both 34mm. If your stock, a 34mm is a good choice. I'm currently running a Mikuni TMX38. I got it really cheap off of a 2000 RM125. I was in the same boat as you and needed something better. It took a lot of rejeting since it was set up for a 125. At first I didn't really like it but once I put a DG pipe set on it, they worked really nice together. Besides the pipe and carb I'm stock as well. So I always have my eye out for a good deal on a 34mm or 36mm because it would probably be a better size for my Z.
    Stiles
