Thread: all you guys with tricked out 90s i need some help gettin mine goin!!!!!
    Oswego, IL
    1,858
    i got spark but its not seemin to get any gas i got a new carb on it but the carb i got seems a little different check out the pics it does have a choke on it but it looks like the ones they used back in the day. also as far as timing what can i do to check all that out to make sure thats right? here are some picsClick image for larger version.
Name:	jim 3ww 001.jpg
ID:	138366Click image for larger version.
Name:	jim 3ww 002.jpg
ID:	138367Click image for larger version.
Name:	jim 3ww 003.jpg
ID:	138368Click image for larger version.
Name:	jim 3ww 004.jpg
ID:	138369Click image for larger version.
Name:	jim 3ww 005.jpg
ID:	138370Click image for larger version.
Name:	jim 3ww 015.jpg
ID:	138371Click image for larger version.
Name:	jim 3ww 016.jpg
ID:	138372Click image for larger version.
Name:	jim 3ww 017.jpg
ID:	138373Click image for larger version.
Name:	jim 3ww 018.jpg
    1985 atc 110 for sale
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    uni clamp on air filter
    350x front end
    Baltimore, MD
    6,088
    Without being at your trike, I would make sure you have gas first to the carb. 2nd, you have to have gas at the carb when you open the throttle cable. If you have those, plus spark, then you should be running. Have you tried any ether shot into the carb to see if you have any combustion. Not alot mind you, but enough to check to see if everything is working right. If you have piston popping, then you will have to check through your carb.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Oswego, IL
    1,858
    ya i gotta play with the carb i didnt have a lot of time to mess with it
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    Oswego, IL
    1,858
    i get spark but it wont fire with either or nothing??????????? could timing br the problem or maybe my cam is 180 off?
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    Feb 2003
    Australia
    927
    Check the advancer is not 180 off. The easiest way to check the cam is not 180 out is to put the piston at TDC, take off the tappet covers and make sure you have clearance at both valves.. You want both lobes pointing down. Make sure you are not a tooth out with the top timing sprocket as well.
    Mountain Home, AR 72653
    500
    Nice bike............... just step through it.
