Thread: Kicker binding 350X
    1,641
    Kicker binding 350X
    Kicker is binding up on 350X,spring or gear?If gear how hard to replace?
    Very easy to replace, although I have never seen a bad one.....
    I have seen the decompression cam installed wrong causing issues as well as the cable adjustment which changes when the valves are adjusted; If you are running one.......I've seen an improperly adjusted cable cause it to lock right at the top of your kick.
    Lay it on the left full of oil and take off the cover, easy job.
    NEPA
    7,051
    X2 !! ^^^ He's gotcha covered. HAve you had the cover off,or it was working and it just started without being pulled apart?
    I believe it's one he's looking to buy so who knows what gremlin got in there..........
