Results 1 to 15 of 16
Thread: another 70 thread
    Feb 2009
    Rome,NY
    1,046
    another 70 thread
    So I picked a couple 70's up from freaks a few years ago and never really did anything with them but tuck them away in the basement ... ended up putting a 110 motor in the one and painting everything up nice and on the stand it sits (got to get freaks over here to see if we can get some spark before I go any further) So that brings us to the other one ... I ordered one of those 125 lifan motors and got the "kit" one so shouldn't be a problem getting this one running, just pulled it all apart and getting ready to order parts!!! haven't posted on here in a while will have to figure the pics out
    Feb 2009
    Rome,NY
    1,046
ID:	138701Click image for larger version.
ID:	138702Click image for larger version.
    Connecticut
    1,605
    cool! do you have a build thread going for the one with the 110? Be cool to see what you did to drop the motor into your 70!
    Feb 2009
    Rome,NY
    1,046
    No I didn't do one for the 110 but all you really need to do is drill a hole for one of the mounts on the frame and massage it a little to get it in there
    Feb 2009
    Rome,NY
    1,046
    got quite a bit done today , got everything cleaned up and painted except the forks i stripped the paint off them and i'm thinking about a disc brake still .... then again this is getting expensive as it is with the new motor ,rear brakes, bearings ,probably exhaust, bars and all those other misc bits.
    jfaulkner02's Avatar
    jfaulkner02 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2009
    Farmington, MO
    425
    Yep, they can be costly. Sounds like some good progress. Where are the pics?
    Feb 2009
    Rome,NY
    1,046
    I know you guys like pics.... not 100% on tank color yet thinking of going flat black with some flashy red stripes Click image for larger version.
ID:	138996Click image for larger version.
ID:	138997Click image for larger version.
ID:	138998Click image for larger version.
    Feb 2009
    Rome,NY
    1,046
    not a bad day today Tripple-B found my motor on the front step and I found brakes in the mail box!!!Click image for larger version.
    na
    5,702
    Looks like a fun project. The 110 is a really good all around platform for the 70's. Not to wild or mild.
    IMHO if you can swing the coin, do the disc brake set-up on the 125 conversion out front. They really need help with the brakes with the bigger engines, especially if you are gonna do any trail riding with hills. You will thank yourself for it in the end. I want a front disc kit on my Pirhana 125.
    Proudly NOT a member of
    "Team on the Teat"
    Feb 2009
    Rome,NY
    1,046
    Yeah I bought a air cooled r hub with the disc but just want to get this thing moving first. Mosh I was looking your build over earlier and it looks real good is it holding up well?
    Mar 2008
    EastGreenbush, newyork
    3,494
    couple good projects there! moving right along too. hope too maybe see you guys at brapps, i dont know for sure if i will make it yet we will see.
    na
    5,702
    Quote Originally Posted by AutoXer View Post
    I would like to know more about this air cooled hub mod interested for sure.
    Mine is "finished" for now. I never did update pics once I got the CRF 50 shrouds on there. It is holding up well. However, that Piranha 125 motor is making a funky squawk sound in the clutch when it just starts to grab. I was gonna take it apart and look for the problem, but my luck and past noise hunting experiences, tells me to just wait for it to break, and then the problem is easier to find..hehe.
    "Team on the Teat"
    Feb 2009
    Rome,NY
    1,046
ID:	139443Click image for larger version.
ID:	139444Click image for larger version.
ID:	139445Click image for larger version.
ID:	139437Click image for larger version.
ID:	139438Click image for larger version.
ID:	139439Click image for larger version.
ID:	139440Click image for larger version.
ID:	139441[ATTACH=CONFIG]Click image for larger version.
ID:	139442 got some progress and the tank that is on there is for mock-up I guess I got real lucky because the carb is huge and clears the tank. I ordered the pipe last night and I should get the bars and throttle today. The tires are glued on and dry rotted I was hoping to use them for now as new ones aren't really in the budget right now and new plastic is also out. Thinking about the pull start conversion still who knows I might just push it . I still need a few pieces for the headlight also.
    Feb 2009
    Rome,NY
    1,046
    Bars came today now I need to get a brake perch, gripps and hopefully the pipe will be here soon .... would love to bring this to brappsClick image for larger version.
Name:	basement racer 001.jpg
    Oswego NY
    1,935
    Hey autoX... you want me to bring my 125 out to ya to play w? Can see my ideas, i have freaks old 110 setup in aa different chassis here to, i also have my 88 i had at icefest.. alot of different ideas in 3 little bigbore minis.. lol
    MIK6 / Mike
    New England Ride 4/13
