I noticed my 200x engine had a noisy cam chain so I ran it at idle and backed the 14mm bolt a few turns and when I did the engine shut off so i tightened it back up. Then when I tried to start it, it wouldn't. Then I held the gas and kicked it and it started so I turned the idle screw it fully and it would idle just like it did. But why would that happen? Then before I rode it(and I wish I had rode it so I knew it wasn't the valve adjustment) I adjusted valve clearance and I know I did it right, then rode it and the thing is sackless now, it has nowhere near the power it did and it has a high compression motor, an air filter, and an exhaust. What the hell it makes no sense!!!
